Stereophile Review Of JBL 1400 Arrays Using Bryston Gear
0 Members and 1 Guest are viewing this topic. Read 28461 times.
Laundrew
Re: Stereophile Review Of JBL 1400 Arrays Using Bryston Gear
« Reply #80 on: 16 May 2010, 05:26 pm »
...and add these of course... for a holographic soundstage, more air, better defined rhythm and pace:
nap.  :thumb:
 :duh: :!:
vegasdave
« Reply #81 on: 16 May 2010, 07:26 pm »
Can we get back on topic...please? lol.  :lol:
Napalm
« Reply #82 on: 17 May 2010, 03:00 am »
Sure. Here's a serious comment after seeing the review.
You wanted some extra bass and treble compared to your existing speakers. Judging by measurements the JBL horns will deliver these in spades. However be warned that being 89 dB sensitivity and a difficult load you may also be looking at an upgrade to a 14B.
Nap.  :thumb:
HsvHeelFan
« Reply #83 on: 17 May 2010, 03:16 am »
If you like horns, may I suggest the Magico Ultimate II's?
I've never heard them, they're huge and expensive.
http://www.magico.net/?d=03_Products/06_Ultimate_II
In the price is no object speaker arena, I was always partial to the Duntech Sovereign's, and there downright inexpensive compared to some speakers,  since those were the reference speakers for some of the RR recordings that I have.
Top of the line KEF's and Thiel's are the nicest speakers that I've ever heard.
HsvHeelFan
Napalm
« Reply #84 on: 17 May 2010, 08:00 pm »
Laundrew, have you ever considered these:
http://mbl-usa.com/Browse.aspx/392/Speakers
they're as steampunk as they can get.
Nap.  :eyebrows:
vegasdave
« Reply #85 on: 19 May 2010, 10:09 pm »
Nap.  :thumb:
Cool, then I have more reason to audition them.
I believe James said the 4BSST is fine?
Laundrew
« Reply #86 on: 20 May 2010, 04:45 am »
Nap.  :eyebrows:
I will take a pair of 101 extremes - please :drool:
Be well...
Napalm
Laundrew
« Reply #88 on: 21 May 2010, 04:43 am »
How about a plasma one:
http://spk.if.uj.edu.pl/ConsciousFlesh/pspeaker/PSPEAKER_en.html
Nap.  :thumb:
Thank you Nap - now this is substance!
 :thumb: :drool:
Be well...
Napalm
« Reply #89 on: 21 May 2010, 01:29 pm »
Probably is. Or you could explore a lateral move - Anthem Statement P2 aka "The Sledgehammer". It's specified for 675 W sustained into 2 ohms. With 8 ohms it doesn't even warm up.
Nap.  :thumb:
vegasdave
« Reply #90 on: 22 May 2010, 05:52 pm »
No, no, I'm not buying another make of amp.
Napalm
« Reply #91 on: 22 May 2010, 06:01 pm »
Dave, I said "explore" not "buy". Like in test them side by side and if the Sledgehammer doesn't do anything extra, then you'll confidently keep the 4B.
Nap.  :thumb:
vegasdave
« Reply #92 on: 22 May 2010, 06:09 pm »
I'm not even doing that...I'm sticking with Bryston!
