0 Members and 1 Guest are viewing this topic. Read 8322 times.
Hey, can you PM that rock song or album you gave to Jim? It was an outstanding hot guitar song!!
Why does the HT3 torture me to find the best components for it and to think I was content before buying these. Thanks again,Steve
I'll 3rd the DNA 500.
Just be careful of matching the tube preamp with it. You'll need a tube preamp with fairly low output inductance.
Again outside the box ---- AVA gear is very, very good and have heard it on many SALK models over a period of time but consideration might be given to the Wyred4Sound products---do not have HT3's but have the 1"s and 2's and although different animals the Wyreds are very good especially after a substantial break-in period(200+hrs). Initially they are a bit bright and that can be a bit disconcerting, but with a little patience they begin to revel some very good sonic qualities. I have the ST-500 but you would probably want more and the ST-1000 or SX-1000(Monos) are an option. The STP-SE is also a very capable pre and you will find that this combo will work in your budget. Happy hunting
