0 Members and 1 Guest are viewing this topic. Read 27972 times.
Did they make ipeng for the ipad finally? I am going to buy one for my wife and I next week I think. So I am looking at the best alternative for controlling the SB.ThanksJared
FYI, there are known issues with Pop3 email accounts (when said accounts are set up via the sync process). Solution: delete problematic accounts and manually re-enter account info.
I can vouch for both the problem and the solution. Thanks for posting Joe!
Has anyone used the camera adaptor (or whatever it is) to get digital audio out of the iPad yet? I read somewhere that this is possible, but can't remember where.
Maybe here? I'll get one soon (with the Apple case, as it seems it's traveling with me more than expected) and will report back if someone else doesn't sooner.
Is their an external 3g adapter for the Ipad?
You can use an iPhone.
Turns out Australian pricing is pretty reasonable (compared to US pricing):http://store.apple.com/au/browse/home/shop_ipad/family/ipadHow much memory are people finding they are using? I'm just wondering how you would use more than 16G.
Got mine yesterday and all I can say is wow!Controlling squeezebox is so much more fun with this toy than either my laptop, Mac mini or pronto.I'm having a blast!
But secretly, I have no reason to have my iTunes music on it, and 16GB should be plenty for a few movies and all the apps you could every want.
Which app are you using to control your squeezbox with on the iPad?thanks!
I'm using the standard web based interface via the safari app. I am also evaluating VNC apps Mocha Lite and iTeleporter. So far, the VNC apps are not as much fun... The screen resolution I need for my plasma display attached to the Mac Mini is too wide to fit the iPad screen. This makes using a VNC kind of clunky.I may also try out one of the other apps like iPeng. If I could only find a wifi to infrared converter, I could replace my Pronto with a truly programmable remote!
