DIY Dodd Buffer
sl_1800
Re: DIY Dodd Buffer
« Reply #840 on: 17 Feb 2011, 12:27 am »
Just a little Dodd Audio tube lust! :D  I borrowed this amp from GR Research, it sounds fantastic.  Gary you really should consider putting these back into production.
gprro
Re: DIY Dodd Buffer
« Reply #841 on: 17 Feb 2011, 01:25 am »
Yeah, what happened to the battery amps? A set of those in mono configuration that could do at least 30 watts might lessen my atma-sphere lust.
Danny Richie
    • http://www.gr-research.com
Re: DIY Dodd Buffer
« Reply #842 on: 17 Feb 2011, 01:37 am »
I love that amp!
Gary is working on a new power supply (or power converter) that will take them up a notch. Maybe we can get him to put them in production when he has finished perfecting them.
HT cOz
Re: DIY Dodd Buffer
« Reply #843 on: 17 Feb 2011, 02:03 am »
That is the one to dream about!
rtate
Re: DIY Dodd Buffer
« Reply #844 on: 17 Feb 2011, 03:17 am »
Atlplasma , form the research that I have done it appears that 8606 would be
a production date of August, 2006....
or 1986 week 6...
but I'm not positive   :scratch:
« Last Edit: 17 Feb 2011, 01:22 pm by rtate »
HAL
Re: DIY Dodd Buffer
« Reply #845 on: 17 Feb 2011, 03:25 am »
I am waiting on the PS upgrade for mine.
It is the mate of the bottom buffer.
dBe
    • PI audio group, LLC
Re: DIY Dodd Buffer
« Reply #846 on: 17 Feb 2011, 05:26 am »
Here is some more...
I love these things.   You can't weld with like you can with a Krell, but they are the best preamp/amp combo that I've had for making music.
Bring 'em back, Gary
Dave
TrungT
Re: DIY Dodd Buffer
« Reply #847 on: 17 Feb 2011, 05:51 am »
More picture please  :thumb:
HAL
Re: DIY Dodd Buffer
« Reply #848 on: 17 Feb 2011, 06:10 pm »
Trung,
What wood is your buffer remote made of?
TrungT
Re: DIY Dodd Buffer
« Reply #849 on: 17 Feb 2011, 11:43 pm »
I don't really know,  but I can find out.
 :thumb:
Danny Richie
Re: DIY Dodd Buffer
« Reply #850 on: 18 Feb 2011, 12:42 am »
Dave, I think yours looks pretty good. There is nothing like matching wood on these things...
Here's mine.  :green:
dBe
Re: DIY Dodd Buffer
« Reply #851 on: 18 Feb 2011, 03:59 am »
Lust is a sin... right?   :drool:
The man just does great work.   :thumb:
Dave
Atlplasma
  • Just off the boat
Re: DIY Dodd Buffer
« Reply #852 on: 22 Feb 2011, 10:57 pm »
I've had the 6H30-DR tube for about a week and am really enjoying the added bass and detail (compared to the standard 12AX7). Trung keeps telling me the sound becomes truly magical once the caps settle in after a few hundred hours. Can't wait!  :thumb:
dBe
Re: DIY Dodd Buffer
« Reply #853 on: 22 Feb 2011, 11:22 pm »
What Trung said  :thumb:
Dave
jtsnead
Re: DIY Dodd Buffer
« Reply #854 on: 24 Feb 2011, 05:50 pm »
So has anyone tried using pointy, squishy or wood supports under the Dodd Buffer?
I tried some myrtle wood blocks and could not tell a difference, maybe because the
thing is like a little brick and already has some nice feet.
Oh and I have the factory built version
TrungT
Re: DIY Dodd Buffer
« Reply #855 on: 24 Feb 2011, 07:11 pm »
Tighten the bass a little, but ... just me.  :thumb:
jtwrace
    • TIPP YouTube Channel
Re: DIY Dodd Buffer
« Reply #856 on: 24 Feb 2011, 07:50 pm »
sl_1800
Re: DIY Dodd Buffer
« Reply #857 on: 25 Feb 2011, 01:31 pm »
I use sorbothane semi spheres under most of my equipment.
jelt2359
Re: DIY Dodd Buffer
« Reply #858 on: 26 Feb 2011, 06:55 am »
Just got my Dodd Buffer. It's outstanding. I emailed Dodd about customs issues, and got word that he is in the hospital, unfortunately.. :( I waited more than 2 months for this buffer, but health is more important.
Atlplasma
  • Just off the boat
Re: DIY Dodd Buffer
« Reply #859 on: 26 Feb 2011, 01:30 pm »
Let me suggest that everyone send Gary a get-well note or card. I'm sure he would appreciate the support.
