Cheap and Cheerful cost:kit - $325scrap wood, Shack or eBay - $? (cheap)if I want to get fancy it can go up in thousands. Here is the link to the kit info:http://doddaudio.com/diy.aspx
No knobs? You have to have knobs. It's cheap if you have the time to make one and debug it should you make a mistake. Oh, and have the tools necessary to solder and make a case. Start buying tools and the cost skyrockets. Sort of like working on your own car is cheap if you have the hundreds to thousands of dollars in tools necessary to do work on a car.
man, I hope he does an amp kit as well. Since I already have a buffer, I'm good there but a Dodd Tube amp kit. I'd send the PayPal NOW.
My guess is that it's a possibility.Most likely depending on success of this offer. Would I sign up for amp kit? Most likely. Let see how it goes. I see that Gary is working on finishing touches and polishing/adding instractions on his website. Mariusz
I am thinking about using Gary's buffer with ClassD and making integrated stereo amp.
Hey all I have had several ask if the buffer could have a HT bypass. This version cannot have a bypass feature, it would require a lot of rework.I could do a bypass, but I really think that in some cases there would not be enough volume for some movies and such. I have done a few with a tape loop, but that's about as far as I think it should go for this version.Gary
I think Dodd Buffer template is cool, I'm bad about measurement, so this template realy help.Just print, placed where you want it (masking tape to hold it in place), automatic center punch to the + marks, pick out the drill size, making all the holes. No guess work there. http://doddaudio.com/Documents/doddbufferholepattern.pdf
Execution is the other half.Can not wait to hear this kit in all its glory.
Any plans on other DIY offers from Dodd Audio?(if this kit becomes a success !!!)
