Anyone replace they're TVCs selector switch?
0 Members and 1 Guest are viewing this topic. Read 5010 times.
Martay50
« on: 5 Apr 2010, 10:41 pm »
Hello everyone...
Just got my ref 4 TVC today but it arrived DOA due to a funky selector switch. Instead of sending it back to Nicholas, I'm considering replacing the switch myself with a higher quality unit. Anyone done this themselves? Which switch did you use? How easy was it? Any advice would be appreciated...
system:
Esoteric DV50s universal player
Promitheus ref 4 TVC
Aleph 2 clones mono amps made by Tim Rawson
Aerial 7B
DIY interconnects, power cables, Basis speaker cables
rollo
  • Rollo Audio Consulting -
Re: Anyone replace they're TVCs selector switch?
« Reply #1 on: 17 Apr 2010, 01:42 pm »
  Yes, if you must have one then DACT 5x 4 at $125. Excellent switch. If you can use one input and switch when using another component my recco would be to eliminate it altogether. Less contacts, less wire, better sound.
charles
Martay50
« Reply #2 on: 17 Apr 2010, 05:29 pm »
...Hey thanx Charles/Rollo...
Checked out the switch and it looks like a high quality unit. Unfortunately, I have more than one source so I need the switch, otherwise I'd take your advice and eliminate it altogether for better sound. Looks like I won't have to replace it anyway...Nicholas has sent me a new ref 4 TVC. But, it's good to know a good source just in case...
cheers,
marty
rollo
« Reply #3 on: 18 Apr 2010, 03:01 pm »
cheers,
marty
Enjoy !!!!!!!!!!
charles
