I haven't tried the 6700 but they look to be very close to the DA wheels. I'm sure they'll be great. Still, you should find a shop that will let you demo a set of silly wheels like Zipp 404 or the HEDs. Just for grins. You can usually find wheel demos at cycling events too.
Hey Jack,Unfortunately is has been a bleak winter for me. A lot of work, which I guess is a good thing, but very little exercise and a half way decent tire around my mid-section because of. Actually I've been fortunate to have less flat issues with tubulars than clinchers. And while I would not take a downhill corner at 45 mph on a un-glued tire, with reasonable care you can make it safely back home without the least bit of worry. Offer still stands, I'll send you some wheels to try out for a while. Shameless plug, anyone looking for a nice crank, drop me a pm. NIB; Zipp 300, Campy Record, Campy Centaur(carbon)
On a side note, I rode in the worst wind I can recall yesterday. Only made it 30 miles but it was painful. My group did 70 and averaged over 17.7 mph for the ride. They are officially too fast for me. I'm officially on my Carmichael Power Training regiment, starting today. Need to get faster...
Would you "cheat" by getting an aerobar? I just ordered a Profile Design T2+ DL. Never used an aerobar before so very curious to try one out. I am going for a 60 mile ride tomorrow. It would be my farthest weather permitting.
Aerobars are not cheating. Some group rides will discourage aerobars because of safety concerns. On a traditional road bike, when using aerobars, it's often difficult to access brakes and you are more likely to crash if you have to access brakes quickly. We generally ride on country roads and there are very few fast stops so it's less of an issue. If you use them, just be careful around other riders and don't use them in a pack unless you are the lead rider. Some guys who use them in my group do a lot of solo riding during the week and aero bars are very helpful in this part of the country because we have some intense wind this time of year and during the winter.
Duly noted. Personally, I will only use it on straighter stretches when no one is around me. At least until after I gain full confidence in using them.
