There are a lot of nice wheels out there. I'm old school, so I prefer tubulars. Not been on a set of clinchers I like better. Especially when it comes to the carbon wheels. Knock on wood, I've had better luck flat wise with tubbies too. The 1/2 lb weight savings can't hurt too. Other opinions may vary.WNC, couldn't quite make out yours in the picture? How do you like the S-Works?
The old wheel dilema. Checking the spec on the Shimano, the 23mm rim height is not aero. I would go at least 30mm rim height at the minimum at the front and rear. It may look silly if you only have one aero wheel in the front vs the rear. It will definitely work without problem. I would wait until you can afford to get both wheelset or go for a custom wheelset. Go custom.
I have a pair of the Dura Ace wheels. They're very nice. I upgraded to a pair of HED Ardennes SL. The Dura Ace wheel set is light, durable and in 10k+ miles I only had to true them a few times very minimally. They're perfect training wheels.
Wheel set upgrades are the best bang for your buck you can get. I highly recommend going for a nice set. But I don't know if I would go for two different wheels on a bike. Different wheels tend to feel different and ride differently. You might end up with some strange results.The RBR thread is pretty much my experience too. I bought the HEDs not because they were lighter or more aero - they aren't much better in either case - but I like the way the C2 rim width rides. I also wanted to build a wheel set for a Powertap I had. I hardly ever ride the DA wheels now.
Thanks for your reply again.Would you say your ride comfort level when riding on DA wheels was pretty smooth, but HED wheels are just more comfortable hence allow you to ride farther? Just wondering because I don't feel any discomfort when riding on Shimano wheels so comfort wasn't high on my priorities. Or, at least, I was not aware of the importance of a more comfortable wheel. I think I will go to a LBS that stocks HED either today or tomorrow and figure out whether HED is right for me and, if so, which one. Definitely would like to find out that I can get away with the lower end model.
I'd test out the wheels before you buy anything (if possible). I'm a big fan of HED rims but your stock Shimano are good enough for training and you probably will not notice a big difference with the new rims (unless you ride some very steep hills). I'd save up and get a pair of wheels when your current wheels start to break down.
If you are concerned about ride comfort, you might want to just look at getting new tires. Continental GP4000's will make a bigger difference on your ride than most people imagine. Also, if you ride some rough roads, you might want to look at 25mm tires. You can run lower pressure and they aren't much heavier than 23's.
One of the fastest riders in the group is a guy in his 50's who rides an old aluminum Giant TCR (I think that 's the model) with an XT MTB rear deraillier, a triple crankset, stock low-end Shimano wheels, and generic tires. His bike probably weighs around 20 lbs. and is probably worth less $$ than the bottle cages on most of the expensive bikes in the group. His chain has seen better days and it looks older than the bike, but he's a demon, especially on hills and he can usually be found at the front of the pack punishing the group by pushing the pace in his low-key, modest style.
I'm not saying gear doesn't matter and I'm not saying it's not fun buying cool bike stuff but the first guy is way cooler (IMO). His only focus is on bike fit and comfort. He logs tons of miles and rides several tough rides like the Horribly Hilly 100 and several torture rides around the country. He replaces things when the break but makes no attempt to make his bike lighter or more impressive looking. I usually only see the bike at rest stops anyway because I'm usually at the back of the pack with the Colnago guy (nice looking bike)...
Comfort is about the same for both sets. The HED Ardennes wheels have what they call their C2 rim which is wider (23mm) than you'll find on most road wheels. The wider rim allows the tire to have a wider contact patch - more like a tubular in that respect. It really does make a difference in handling. I also feel comfortable riding a lower psi (95) with the HEDs. It's a bit softer riding than the DAs with 110 or so. We have a lot of chip seal roads here and a fatter tire or lower pressure smooths out the buzz from the crappy road surface. The HED C2 makes the lower psi more reasonable. Running the DAs at 95 feels squirrely I am sure you can find a shop that will let you demo a pair of new wheels. You 'll get a taste of what a nicer set of wheels offers and you can decide from there. I think you'll be impressed.
Those HED's sure look cool. My friend has a Powertap set he built (with Sapim spokes) and he loves them. I'm happy because he's selling me his old PT set!
Well, I did visit a store that claimed to carry HED on their website. But, turns out the store is still "working out the details." Instead, they tried to push Reynolds and Mavic pretty hard. The sales guy did immediately point out the hubs on my R500 are very heavy.After much contemplation, I am getting for the Shimano 6700 from Chain Reaction Cycles. It's cheap and should get me most of what the higher end wheels offer.
