New production 6SN7 recommendations?
Ericus Rex
Re: New production 6SN7 recommendations?
« Reply #60 on: 16 Dec 2010, 06:36 pm »
Also, I see they have a 2a3 and 300B, no chance that there is an 845 I'm not seeing, is there?
Synergy Hifi is showing an 845.  $600 pair.
http://www.synergyhifi.com/product.asp?tid=10
rklein
  • My finest audio piece ever!!
« Reply #61 on: 16 Dec 2010, 07:53 pm »
Gopher:
The Creates can be bought at the below site as well:
http://www.aloaudio.com/store/index.php?main_page=product_info&products_id=377
However, it seems that they are no cheaper than SynergyHiFi except that you are dealing with a US distributor.  I believe that Bunky bought his Create 6SN7's here.
Randy
Gopher
« Reply #62 on: 16 Dec 2010, 08:40 pm »
Lotta cabbage,  I'd stick to Pavanes direct from China for half that... or even from Grant for 4/6ths.
The preamp tubes are still interesting though
Ericus Rex
« Reply #63 on: 16 Dec 2010, 10:59 pm »
Gopher:
Randy
Shipping should be a little cheaper since these guys are stateside.  You might save 5-10 clams I'd think.
roscoeiii
« Reply #64 on: 12 Feb 2011, 10:32 pm »
Well folks, looks like there is a Pavane/Psvane CV181-T/6SN7-T coming out. Currently only available with the Shuguang 845 amp described in the link below. I have e-mailed Grant Fidelity for details of when it might be available for sale separately.
http://grantfidelity.com/site/shuguang_psvane_845T_SET_monoblocks
bunky
« Reply #65 on: 12 Feb 2011, 11:10 pm »
Ricky Xia of Hanshare electronics in HK just sent me another pair of Treasure CV181-Z's that he hand matched from the best ones in his inventory for my linestage and i rolled the other matched CV181-Z's that were in my linestage into the Niteshade NS-40 replacing the Create/Synergy 6SN7's that were in it.i like the NS-40 even better running the CV181-Z's in it  :thumb:
roscoeiii
« Reply #66 on: 12 Feb 2011, 11:22 pm »
Thanks for the update. Been looking for more comparisons of the Creates and Treasures. Does hanshare have a website?
larbo53
« Reply #67 on: 22 Apr 2013, 04:34 pm »
Has anyone compared the Sophia Electric 6SN7 tube to the Synergy HiFi 6SN7. I have a pair of modified (by Bill Baker of Response Audio, Purity Audio fame) ASL Monsoon mono bloc amps and there are two 6SN7 tubes per mono bloc. Eack mono bloc has a 6SL7 tube and four KT88 power tubes as well. I am currently running Genalex Gold Lion re-issue KT88 tubes.
