Viridian, What was the reasoning behind the choice of the 80Hz crossover point recommended by your friend?
Actually, my baffles won't be much bigger than your eminence woofer ones. I noticed that you extended the baffle on one side. Why?
The offset helps smooth the ripples from front-to-back cancellation in the frequency response for the ToneTubby. I used MJK's MathCad worksheets to simulate the driver's response on that size baffle and pin down a more optimal location.John
Hi Viridian, pardon my jumping in, but do you recall where MJK said that a U-frame has no cavity resonance? Thank you in advance.
