0 Members and 1 Guest are viewing this topic. Read 13737 times.
Thanks, I do think that that helps. I'll get some cheapo chokes to try things out.
Will you let us know where you find some cheap chokes?Thanks,Dan
Where have you looked?
Sorry, but it's hard to imagine how this could possibly work out. Is you tube amp going to drive this load? Woofer impedance might drop to 3 or so ohms at some frequencies. Probably even lower, as the Pioneers will be doubling in the bass. They are in parallel with the subs.
It can work, though no guarantee that it will. The attached impedence curve is for FIVE 8ohm 12" drivers wired in parallel. I dare say any amplifier could drive this load.John
Erse makes decent stuff. Here's their inexpensive line of steel-core inductors: IQ Coils.John
