0 Members and 1 Guest are viewing this topic. Read 5181 times.
Absolutely they can be used in a home setting. Not sure what gerald porzio and drphoto have tried but I use Yorkville Unitys to great effect in my home setting. I actively triamp them with a DEQX 2.6P as preamp / crossover.The Yorkvilles combine great quality drivers, a nice cabinet, and the Unity horn into a very reasonably priced package. Might not look great (according to my wife anyway) but they sound terrific with dynamics unapproachable (imho) by more "domestic" speaker types.-Jim
I also use the U15's, and agree that with a little massaging and tweaking they are amazing speakers as mains. The aren't exactly your run-of-the-mill pro audio cabinets though. Still, the value proposition is staggering compared to conventional hi-fi IMHO.JDUBS, can you export xover settings from the DEQX? I'd be very interested in seeing what you're using. I'm moving (excruciatingly slowly, but moving) towards an active tri-amp set up for the U15's as well....
I'm not an engineer but I bet that pro audio speakers have different design requirements than home audio speakers.
Often the mids/highs use compression horns which distort/color the sound (due to non-linear compression of the air and vibration of the horn walls - sorry Jack).
Studio work involves very small spaces, again lack of deep bass, and typically involve built-in amplifiers. These tend to be very accurate and detailed (to the point of being "overly analytical"). The bass extension/output, dynamics, and flat frequency response afforded by the built-in amps is amazing, but typically these speakers lack the "warmth" most want at home.
