0 Members and 1 Guest are viewing this topic. Read 5406 times.
If you wouldn't mind, a few close ups of the Wadia please. This is a piece of gear I'm really interested in getting and I've never seen one on a forum. Perhaps you could give a quick run down of how you like this piece of gear as well? I'd be hooking it up the same way as you, through an AVA preamp to a 240.
Great looking speakers! I'm a cherry guy myself. Can you pull them off the back wall some?
Thanks. and...Yes, they are too close to the wall and not aimed well either. Tomorrow is experiment with placement and aiming time. My wife will be gone all day, so I can slide furniture around and do things like that without her complaining.
Thanks for the pics, they are really helpful. I see there is a remote, which I didn't think there was. Now I'm really intrigued. Can you change playlists with it? (as in, switching between a Rock and Classical playlist on the iPod, not what songs are in them). I pretty much thought you had to put the thing on random play and let it go, but if you can somewhat browse the iPod playlist menu, this might be a must for me. I have all my songs in Apple Lossless on my Mac and iPod already. The remote will not change playlists, and the playlist does not display on the TV screen. However using the remote, it will change to the next and last song. It will do play and pause. It will change modes from analog to digital. And there is a +/- button and I forgot what that does! And if you use a universal remote or a remote that has learning, you can program those functions into your main remote. And yes it charges.Edit: Does it charge the thing as well?
