Audio/Video Gear and Systems
The Acoustics Circle
Rob Babcock
Looking for intro to using and buying RTA
0 Members and 1 Guest are viewing this topic. Read 1670 times.
joschmo
19 Mar 2010, 02:32 pm »
I have never used an RTA and looking for some info on using and buying one (cheaper would be best) and learning about measurements. Your help is most appreciated.
jtwrace
Re: Looking for intro to using and buying RTA
19 Mar 2010, 02:45 pm »
The most cost effective would probably be Room Eq Wizard. You can download it free and all you need is a mic (RS SPL Meter) and sound card.
http://www.hometheatershack.com/roomeq/
There is also a help forum on on the shack site dedicated to REW which you'll need.
joschmo
Reply #2 on:
24 Mar 2010, 01:08 pm »
Thank you
Rob Babcock
