My next uprade will be to purchase the P-3A. Can you send them directly from Perpetual to Empirical to have the mods done?
Is SOCS for 2 channel, Home Theater, or both?
What if you listen to music in PL2?
You shouldn't... Sorry, not a big fan of multi-channel music.GW
Quote from: witchdoctorWhat if you listen to music in PL2?Then what I said above about HT, with five of the same full range speaker, and using no distance or time delay settings (or other additional processing...forgot to add this earlier), this should all theoretically work. Like I said before, though, SOCS is currently specifically for 2-channel listening.
And for HT, realize that SOCS/RCS corrects phase by delaying the audio, just some of the frequencies by less time than others. If you're playing vid ...
