DAC
0 Members and 1 Guest are viewing this topic. Read 4375 times.
dnewman
Re: DAC
« Reply #20 on: 25 Mar 2010, 04:35 pm »
It seems like it would be a worthwhile project.What kind of transformer and chassis did you use?
I installed the HagDac in a Transcendent Sound Grounded Grid Preamp and that unit has a very roomy chassis.  Thus, I found I didn't need a separate chassis at all.
Dan
david62
Re: DAC
« Reply #21 on: 26 Mar 2010, 10:42 am »
 Dan,
    Putting the DAC  board in the same chassis as the preamp.is nice since you don't have to worry about picking up noise with a longer cable run.What are you using for a transport and how does it sound?I'm thinking that building the power supply and assembling the DAC so I can use it with my Clarinet may be a good project for next fall or winter at this point.
Dave
