0 Members and 1 Guest are viewing this topic. Read 13979 times.
NagysI'm confused on how the bubble wrap would allow the sound waves get "absorbed" into the wrap. It seems to me the sound waves would just "bounce". Can you explain?
Just curious to see if anyone else out there has any experience with it.
Then we can find out if the bubbles need 40 to 978 hrs. of break in.
I suggest some of you speaker builder out there to try it.Oh and if anyone packs their electronics with bubble wrap, YOU are the problem for all the damaged equipment.
Hey guys cut Nagy a break. When and if you try his recco then comment. It just may work well. Yes Nagy is a bit agressive but does not deserve a bashing YET that is. If we find his reccos BS than by all means fire away but please not until then. My 2 cents.charles
