cable length
Derockster
cable length
« on: 14 Mar 2010, 06:21 pm »
Hi guys,I would like to know
1 What's the maximum recommended length interconnect the TVC will drive?
2 Has anyone ever tried a longer length than what's recommended?
3 What are the losses sonically if a longer than recommended length is used?
Regards derockster
rollo
  • Rollo Audio Consulting -
Re: cable length
« Reply #1 on: 14 Mar 2010, 06:25 pm »
Used 5 mtr. with no loss of anything. low capacitance is reccomended though.
charles
Derockster
Re: cable length
« Reply #2 on: 14 Mar 2010, 06:36 pm »
Hey Rollo,correct me if I'm wrong 5 mtr. equals 15ft?What brand cable did you use?
srb
Re: cable length
« Reply #3 on: 14 Mar 2010, 06:44 pm »
5 meters = 16.4 feet
Derockster
Re: cable length
« Reply #4 on: 14 Mar 2010, 06:48 pm »
Thank you Steve. :thumb:
rollo
Re: cable length
« Reply #5 on: 15 Mar 2010, 04:46 pm »
  Tara Decade and Audio Research Litz. The Tara a bit sweet the AR neutral.
The Promitheus trannies are designed to accomodate cables up to 5 mtrs. No problema.
charles
Derockster
Re: cable length
« Reply #6 on: 16 Mar 2010, 02:37 am »
Hey Charles any idea where I can purchase some Audio Research Litz cable from?Regards Cleaton
rollo
Re: cable length
« Reply #7 on: 22 Mar 2010, 05:32 pm »
  Audio research  :duh:, sorry couldn't resist, or any Audio research dealer. Check AR website for dealers. Finding it used is tough because not many sell after purchase.
charles
