0 Members and 1 Guest are viewing this topic. Read 4358 times.
In general, which is how you posed the question, your preamp.
in general, what piece of gear should one look to upgrade first, their amp, or pre amp?all things being equal which component in general would yield more of a benefit after upgrading.
Don't upgrade anything unless you have the speakers you plan to use for some time. If you have the speakers everything you upgrade will impact the sound. I think the route I would go (which I have) would be preamp, source, cables and amps.Good Luck,Ken
The question is too vague because it makes the assumption there is a weak link, but we don't know which one it is. My advice: Don't put a $100.00 saddle on a $50.00 horse. Find the weak link and replace that, whatever it may be.
There is no meaningful answer to this query in my opinion. There is no way to know where the weakest link is. Is it the preamp or the poweramp. The source component must also be part of the equation as well as the speakers. Another thread addresses the room speaker conundrum. Any answer must deal in specifics and not generalities. You have posed a general question to which a general answer cannot be given.Scotty
