Would you folks like a demonstration of this upgrade process? You are not allowed to blame me IF you do it wrong.
I have a question for everybody: The electrolytic capacitors can be upgraded. However, since this is a double sided board- it's not going to be easy. The caps they're using are low computer grade and have a lifespan of 1-4 years. The trick to taking these out: You cannot desolder them! The solder is used as a heat transfer medium that can wick up to the top side. Solder cleanup takes place after the part has been removed. Since the leads cannot be clipped from the top-side, the legs have to be heated one at a time from underneath. The capacitor(s) has to be gently pulled from side to side (left, then right, etc..) until it is free of the board. Your iron cannot be too hot or board damage will occur. The tip has to always be clean. Once you get the hang of it, the upgrade process will go fast. Do it wrong and the board can be destroyed. Would you folks like a demonstration of this upgrade process? You are not allowed to blame me IF you do it wrong.
The capacitor upgrades just arrived from Mouser. I will let you know when the upgrading process begins.
