0 Members and 1 Guest are viewing this topic. Read 11798 times.
It looks like psu or motherboard related.I have a Winmate dc-dc psu which is similar to the pico but much better quality. Before i had a normal psu (with fan).Replacing the psu with one proved to work is a good idea. The pico is not well filtered and may be the cause. Also it could be just the wall wart that you use with it.If it doesn't work, go for the mainboard.
I'd like to try the Winmate with my new board. Where did you get the AC adapter for it? Or did you buy it as a package?thanks!DC
Interesting thread on Pico vs. Winmate.Dc
I have the OrigenAE H5 case, with the onboard mATX psu (so no big psu for me), and needed a totally fanless system (which is NOT iATX, but a rather powerful intel dual core).ATM I have an internal soundcard, and the Winmate with the Gateway AC adapter sounded better than the OrigenAE PSU. For me the internal card is a temporary solution, so my goal was fanless and cool. Fanless traditional PSUs would have put too much heat inside my case.
I was thinking about trying a cheater plug in the meantime. The AC adapter that came with the PicoPSU changes the sound when I move it in my hand. AND, If I push the AC plug to one side on the brick, the noise changes and lessens dramatically.So let's say there is a grounding issue somewhere and the noise should be dumped to ground but is not; it is still amazing how much there is and that the connection on the AC adapter makes such a difference.I need a simple and elegant power solution.There seems to be some disagreement over whether or not the Pico PSU has a benefit or not, in that it passes the 12V unregulated and direct for the AC adapter. The Winmate is supposed ot have more filtering. The PicoPSU has solid caps but some say too small; the Winmate does not use solid caps.I'm not an expert so I don't know what matters. I may want to try a linear powering either 3.3., 5. or 12v on the PC though.
Jon, do you run wireless internet? Any routers near your listening space?
