SW12-16 OB Servo subs in H-frame
0 Members and 1 Guest are viewing this topic. Read 24072 times.
TomS
Re: SW12-16 OB Servo subs in H-frame
« Reply #40 on: 22 Mar 2010, 12:51 am »
Can  you tell what's different (sounding) between the sealed sub and the OB subs?
Not really.  It would take a lot of swapping in and out and re-setup to get to that answer and it really needs to be measured for that.  At the moment I'm crossing the sealed one over at 50hz but at a somewhat reduced level (kind of filling in only), and the OB's are at about 80hz acting as the main subs L and R.
The best way to describe it is the OB's are darn near invisible, sounding as quick and direct as the mid/woofer.  I know in a technical sense it's not really about speed, but it just sounds very continuous, like it keeps going deeper without any obvious transition.  The sealed sub adds just a smidge of that visceral physical impact you can feel that the OB's don't.
TomS
« Reply #41 on: 28 Mar 2010, 07:19 pm »
Final setup with all 3 subs and OB grills finally done and installed.  I think the grills were the hardest part of the whole project - ugh, but done feels (and sounds) good.
Hugh
    • Angel City Audio
« Reply #42 on: 28 Mar 2010, 07:24 pm »
Tom,
WOW. :drool:
mcgsxr
« Reply #43 on: 28 Mar 2010, 07:38 pm »
Congrats on building some excellent gear, and big kudos for finishing it - I know that my DIY projects often fail at the 90% completion stage, and the cosmetics take years...
Well done!  Thanks for sharing.
cujobob
« Reply #44 on: 28 Mar 2010, 07:43 pm »
I have the same speakers and one of the subs...but envious my friend, nice work!
rajacat
  • Washington State
« Reply #45 on: 28 Mar 2010, 07:48 pm »
 Looks great. :thumb: I'm sure it even sounds better. That's the sub setup that I'm working towards.
-Roy
poseidonsvoice
    • 2 channel/7 channel setup
« Reply #46 on: 28 Mar 2010, 08:03 pm »
You've got to have one of the top systems in Indiana! :drool: That's pretty much the sub setup I'll have as well, except the low end will be a pair of 18 inch Maelstrom-X's in sealed enclosures.
Should be great for audio and home theater.
Anand.
mgalusha
« Reply #47 on: 29 Mar 2010, 02:57 pm »
That is mighty sweet Tom and I suspect I've a pretty fair idea of how it sounds.  :thumb:
playntheblues
  • D-Sonic, Mola Mola TamBagui, Tekton DISE
« Reply #48 on: 10 Apr 2010, 01:41 pm »
Outstanding  :eyebrows:  And now it's my turn to go down this road but as I mentioned to you the other day I will need to fine a cabinet worker here in Dallas as I don't have the tools, work space or talent required for such fine subs.
dvenardos
« Reply #49 on: 13 Apr 2010, 03:57 pm »
How did you do the wiring from the subs to the amp?
I am trying to figure out if should mount a binding post or speakon on the OB frame, or make a short stub with a speakon, or run a longer wire with a speakon.  :scratch:
TomS
« Reply #50 on: 13 Apr 2010, 04:28 pm »
I just used the 4-pole Speakons with about a 5' cable in techflex
dvenardos
« Reply #51 on: 13 Apr 2010, 05:17 pm »
Thanks.  :thumb:
corndog71
  • Some people call me Rob.
« Reply #52 on: 13 Apr 2010, 08:01 pm »
You can tell I've been on the dark side of this hobby for too long because it always throws me when I see people still using regular old zip cord. :scratch:
TomS
« Reply #53 on: 13 Apr 2010, 10:17 pm »
If you're talking about mine, sorry but that is silver coated copper with teflon insulation...  Pretty good zip cord  :wink:
corndog71
« Reply #54 on: 13 Apr 2010, 11:04 pm »
nice! :thumb:
Bear
« Reply #55 on: 19 Apr 2010, 06:16 pm »
Does anyone have a freq response for the sub section(I found the super v chart) of the super v?
Shane
Danny Richie
« Reply #56 on: 19 Apr 2010, 06:53 pm »
The frequency response is completely adjustable with various settings, EQ, etc. It will play as high as 300Hz and as low as 20Hz (flat), and a -3db in the teens.
Bear
« Reply #57 on: 19 Apr 2010, 06:55 pm »
Awesome, thank you.
Voiceray
« Reply #58 on: 20 Apr 2010, 01:23 pm »
Was there a cabinet resonance in the 200's Hz to eliminate.
Ray
Danny Richie
« Reply #59 on: 20 Apr 2010, 01:42 pm »
No.
