Inexpensive integrated amps w/ USB Dac
Christof
« on: 7 Mar 2010, 09:02 pm »
I'm in the market for a cheap integrated amp with USB dac.  There seem to be a handful of sub $1k units available.  Lets take things one step further and look at sub $500 integrated amps...
Can you add to this list and give comments if applicable:
Firestone Audio Big Joe III
Nuforce Icon
Peachtree audio Decco (refurb is under $500)
Mod...maybe this goes in cheap & cheerful circle?
Mariusz
Re: Inexpensive integrated amps w/ USB Dac
« Reply #1 on: 7 Mar 2010, 10:13 pm »
Glow Audio Amp One.
Original version will save you some but word out there is that DAC is a bit better in the latest model. (did not have opportunity to compare - so I can not say).
Get it cheap and send it to Bob Backert http://www.rhbsounddezign.com/.
Worthy mods given that your speakers are HE.
If not ??????......  How about D-amp kit with ready-DAC board from eBay.
(upsamling, nos .....whatever you need/like)
cheers
Mariusz
knut_the_viking
« Reply #2 on: 8 Mar 2010, 10:23 pm »
Glow Audio Amp One.
cheers
Mariusz
If you're looking at low-power integrated tube amps, I just have to counter Mariusz' suggestion by mentioning the Tec-on model 55
http://www.teconaudio.com/model_55.html
I have one, I use it with a pair of Tekton model 4.5 high-efficiency speakers. Really does sound nice.
New $400. (And my own is NOT for sale :-)
droht
« Reply #3 on: 9 Mar 2010, 10:17 pm »
Christof, not sure if you need a "one  box" solution for some reason, but in case you do not I will recommend the Maverick Audio TubeMagic D1 USB DAC (and tube pre; w/headphone output) + a Virtue One t-amp.  The Maverick DAC is maybe $225 new.  You'd have to pick up a used Virtue amp, but as they are starting to deliver second gen products now I would expect to see some originals on the market soon.  Certainly should be attainable for $250 max.
This is the C&C set up I am running, so I am obviously biased.  :)
The Decco refurb, in comparison, is much larger that these two pieces combined, and imo not in the same league sonically.  I A/B'd the Decco vs the Maverick/Virtue combo.
Lots of other amp options out there as well.
Good luck.
Pchelac
« Reply #4 on: 14 Mar 2010, 11:16 am »
Sweet Peach tube amps, http://www.xshn.com/en/display.asp?id=20, 250$ +shipping , some diyaudio.com members found it sounds good.I'll put my hand on it soon, I hope.
mlgill
« Reply #5 on: 25 Mar 2010, 03:55 am »
I am happy to relay that Dayen Audio's Ampino integrated ampifier is represented here in the US and Canada now by Arte Forma Audio .  It will have its debut at this years AK Fest in Detroit.
lextek
« Reply #6 on: 27 Mar 2010, 07:06 pm »
cheers
Mariusz
Have a link or info on this kit?  I've been playing with a Audio Magnus Tweak kit T-amp and am impressed by it.
Mariusz
« Reply #7 on: 27 Mar 2010, 07:54 pm »
Actually, these are two different kits.
Both have their own threads in the Lab Circle.
One is build by Blair of Nightshade Audio.
The other shows 3 or so exemples of DIY DAC kits.
Mariusz :thumb:
