0 Members and 1 Guest are viewing this topic. Read 41046 times.
Congratulations to Jim and the team on this.I'm ready to fit them in the following space
I can see that the mid/tweeter module is made of laminated sections. Does this same construction extend to the woofer module?
If so, what is the resultant wall thickness (I assume the same section pieces would be used whether MDF or Bamboo plywood), and what is the approximate weight of either version?
Steve - As for the top sections, we will do that for only a short time until we make a mold. From that point on, we will mold the top section with a custom polymer formulation that will be slightly more dense than MDF. - Jim
How heavy is HT-4? Heavier than HT-3? 150 - 200lbs?HT-4 costs twice the price of HT-3. I wonder what the difference is - particularly the SQ...Well,I'll never know unless I buy a pair, and A-B them with my lovely HT-3s.. If only I had room.. Darn!
>The HT3 can't deliver the bass nor soundstage the open back mid of the HT4 allowsOh please... don't tell me that! I just bought it:-) Again, how heavy are the individual pieces?and hello from the sunny sunnyvale (albeit a bit chilly)!
Congratulations to you and your team! We need pictures. ; )The Salk Demo on the West Coast seemed to go very well.
Just curious, what Salk demo on the west coast? When and where did it take place? Was it open to the public or was this where the SoundScape comparison held? I would have loved to have attended nonetheless!Thanks, Garth
Well, hopefully you didn't think Jim would try to sell a $10k speaker that wasn't better than the HT3. That's kind of what this exercise has been all about. As for size, the 10" version doesn't look any bigger than the HT3 from the front. The difference is in the depth--the bass portion of the HT4 is about 7 inches deeper than the HT3.
I'm sure it's been mentioned. What ribbon tweeter is being used in the HT-4?Looks like a RAAL?
It is a custom RAAL tweeter. Aleksander did a great job with it.- Jim
What's custom about it?
Tap values were selected to allow for flat response, -1 1/2 db and -3db response out of the same driver with no change in the crossover for these settings.- Jim
