0 Members and 1 Guest are viewing this topic. Read 41052 times.
The adjustment can be done by the user on the fly, or at the factory?
You can pop the rear magnetic grill off and stuff the cavity of the mid if you wish/need. I'm not smart enough to say when the need arises.
Jim, are there set(base) prices for the 10" and 12" MDF? Thanks
Will there be an active version of the SoundScape released, or instead perhaps a version that includes a multiple filter PEQ to be used to adjust the bass driver's frequency in-room?
JimWill the bamboo cabinets be bamboo ply or solid wood sheet?
Jim this may have been asked, but what is the lower extension of the woofers in the SS-10 vs. the SS-12?
What is the sensitivity of the SS-12 and SS-10 ? I dont believe i ever saw it?
The ultimate -3dB point is very close between the two. The SS-12 has an F3 of 18Hz and the SS-10 is about 19Hz. The difference is in the sensitivity with the Soundscape 12 being almost 3dB more sensitive (Dennis can correct me if he was able to level the crossover out differently than this, but I think this is how it should work out based on the modeling). Then the 12" has a bit more cone area too, so it will be able to reach a slightly higher max SPL. I doubt too many people will ever push things to the point of noticing this though Jeff B.
Jim and Dennis,I was very intrigued by the FAL, Raal combo you had experimented with, and saddened that I did not work out. Is there a chance you will be experimenting with this pair again in some other configuration? They are some of the finest drivers I have ever heard.
