0 Members and 1 Guest are viewing this topic. Read 141986 times.
UpdateI just had to tinker. I opened up the unit. It is not easy to remove the cover , probably because it is new and needs to be worked in.Tube is a pain in the neck to replace.Not convenient laying sideways. Went to my local supplier who will remain nameless :lol:and grabbed a WE 396A and National 396a . Right now I am listening to Shelby Lynne Just A Little Lovin' and the tube has smoothed out the midrange and has given me a more liquid sound.I think the gain is a little high on this unit and after reading the threads about the DAC it said that the new units were being sent out with a lower gain after a few cmments to the manufacturer. I do not know if this is one of those units but the gain could be lower in my system.I have a pair of attenuators somewhere maybe I will see if that helps or I just have to keep the volume on my Pre at a lower point than I am used too. This problem does not introduce distortion into my system. Still a great DAC and I am impressed. I will try the National tube later on in the day and hopefully do a comparo with a Paradisea.
The dealer will not sue you for tampering with opening up the unit? Shoot some pictures while you can see the guts?.....
Once the new water meter is in, will you finally start bathing? Big WAF there, sport! When do you think you'll switch testing from coax to usb, that's what I want to hear about. (Right now using iTunes to break in new xover to my X-LS monitors, thinking a USB DAC would sound good here, but which one?)
This afternoon
Did you try head-amp or preamp (analog) section?(no rush ...... you have plenty time)I will give a 2nd unit a listen today and prep it for NJ guys. BestMariusz
tube pre-outI'm not into headphones
but did you use analog in?or digital in only. No problem with "testing cans" as I'll give it a serious listen ones you guys are finished molesting the crop out of it. Hopefully it will arrive ..... in one piece (actually that unit may stay with one of NYAR-ers) cheers Mariusz
Will there be some kinda group buy on this if there are sufficient interest?
Hey who is the NYARaver keeping this ? He has to get it from me first
We can ask Ryan of Maverick Audio about the group buy and options. I do not see why not. and he might also get the tour discount........
Oh more suprises up his sleeves. What's the tour discount ? who and where do I send funds ?
Can I keep this one and send someone funds ?
(I can ask if group buy is an option and possible savings)
