FWIW, I am using a 160 GB ipod with Apple lossless files. The iPod plugs into the Onkyo dock with digital out. This feeds the coax input of the Mav. This is easily one of the best front ends I have ever heard at any price. Which Onkyo ipod dock are you using, I have been looking at this thread thinking about getting into computer based/ipod audio as an additional source and I would like to be able to run my Nano w/ lossless into the DacAlso my computer only has a usb output no coax or toslink, which usb cables are you guys using?
There is a thread about group buy - also in Cheap and Cheerful hifi Circle. Onkyo transport ND-S1 is similar or the sameas Wadia iTransporter. Not sure if you can get it here in US. Japan and Europe might be the only source (without risk of bootleg replica). P.SI am using this cable (audiogon auction months ago under $60)http://www.audiometallurgy.com/gold-alloy0-digital-cabl.htmledit for link and price adj.
it looks like it would move the the leftthe Onkyo looks like a really good deal, found a post where they opened it up and said it looked alot better than the Wadia.Great buy on the cable, lists for $255.00 nowthis Dac looks like a good affordable way to get into computer based audiolooking at the available software (HD tracks) 96khz seems to be the majority of high rez files, I guess you couldnt change ir 192khz in the future?
Never pulled a tube before, so, I have cover off, see the metal retaining wire, looks like, based on the hinge it needs to move either left or right, as I look down on the unit, with base of the bulb pointing towards me.I think to my right is logical, can anyone confirm?I have a history of forcing things, and breaking them. But then, considering that the retaining wire is pre-bent as if to wrap around the cap on the left, I guess pushing it to left is way to go.Edit: Went to head-fi site, looks like it's the 2 screws on the collar I need to remove.
DAC's performance is excellent for the money. Preamplifier section is locking just a bit of resolution, spaciousness, air and body (90% out of 100) when compared to another great bargain - Nelson Pass buffer (basic version).
Yep, your hearing is almost as good as mine.
This one is Cheap and hopefully cheerful as it is on its way to me, http://www.amazon.com/gp/product/B000E8X5ZU/ref=oss_productwe shall see....LOL
Just push the hold down wire out of the clip. no screws to removw
