0 Members and 1 Guest are viewing this topic. Read 385138 times.
kingnubian, That's looking good. I presume you're getting Gen 1. Are you going to bypass them with anything? I ask because I had some 4.7 Gen 1s in a dac and when I bypassed with a .1 Gen 2, it smoothed out the top end nicely. Good luck.
I let the B-1 "cook" for a long while since the last set of mods (1 uF Penta Labs Teflon cap and silver/teflon wires) before messing around again, and it has come a long way. The transparency and the straight-wire quality definitely improved a great deal. It's gotten so darn good, I figured it's only a few % away from becoming a true world-beater Monster preamp. So I threw the kitchen sink at it. I bypassed the 1 uF Penta Labs teflon with 0.1 uF Aura-T Teflon caps and the 10 uF Jantzen Superior-Z with 0.22 uF FT-3 Teflon caps (awesome in bypass duty). I'll let it burn in a lot more, but already, I can't stop grinning
Jon L, you should email that pic to Nelson Pass along with a description of the caps. I wonder if he ever envisioned such a B1 super mod? AWESOME!
I may have a few extra K73-16caps that I can part with as I now have more than I will need.
Got these in the mail today, 20 (10x10) K73-16 Russian Caps of both 10uf & 1uf rating. I will be pairing these up with some Obbligato Premiums that I have on the way in my B1 build. From everything I've been reading these may be a good mix n match with the Obbligatos. As usual, the proof will be in the pudding.P.S. If anyone is in the Montreal area, it looks like I may have a few extra K73-16caps that I can part with as I now have more than I will need.
I saw this mentioned on htguide. I hear Obbligato are good caps and the discount plus US domestic shipping is a great deal:http://www.hawthorneaudio.com/forums/viewtopic.php?f=18&t=3716
Finally got the B1 to make music! Its powered by a 18 volt wall wart.
Congrats on a very nice B1 build.What caps did you use, they actually appear to fit the B1 board.Thanks for posting the pics.
Case is a tight fit, but I made it work. Seller has larger cases.http://stores.ebay.com/gkphotonics/Aluminum-Enclosure-Boxes-/_i.html?_fsub=1668375016&_sid=79834146&_trksid=p4634.c0.m322
What size is the case you used? Thanks!
