Nelson Pass B-1 preamp kit
0 Members and 1 Guest are viewing this topic. Read 381382 times.
xecluded
Re: Nelson Pass B-1 preamp kit
« Reply #300 on: 13 Jun 2010, 08:53 pm »
Finished my B-1 today, and it is working like a champ.  Went with all the "standard" parts including dual PEC volume controls (not sure if I'll like that, but I do appreciate having a balance control of sorts).
Neil
Neil,
Can i ask what is the part # for the dual pec volume controls and where do you get them at. I am looking to upgrade the pots on mine. Thanks
poseidonsvoice
    • 2 channel/7 channel setup
« Reply #301 on: 13 Jun 2010, 09:05 pm »
Looks like this may be the one. You would need a pair of course.
Anand.
Nick77
« Reply #302 on: 13 Jun 2010, 09:13 pm »
Anand i have seen this link used before also. I like your price point better, but whats the difference between the two??
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=KB2531S28-ND
roymail
  • Roy in TX
« Reply #303 on: 13 Jun 2010, 10:51 pm »
I was wondering the same thing???
There can't be much difference in the two... you'd think.  :scratch:
wushuliu
« Reply #304 on: 13 Jun 2010, 11:48 pm »
Military v. Commercial.
Nick77
« Reply #305 on: 13 Jun 2010, 11:50 pm »
Any reason to spend the extra money??
wushuliu
« Reply #306 on: 14 Jun 2010, 05:50 am »
Nope!
daniloreyes
  • If it sounds good ... Listen to it!
« Reply #307 on: 14 Jun 2010, 07:14 pm »
Which one would be better for the ClassdAudio amps, this B-1 or the lightspeed?  anyone has tried adding the lightspeed to this preamp?
roymail
  • Roy in TX
« Reply #308 on: 14 Jun 2010, 07:59 pm »
LSA integrated into the B1 would be great.  Lightspeed alone would not work with the CDA series amps given their very low input impedance of 3K.  However, the SDS series amps should be good using the Lightspeed given an input impedance of 47K.  SDS-254 would be my preference.
I recommend you give the B1 a try first, then decide whether investing in the LSA is necessary.
roymail
  • Roy in TX
« Reply #309 on: 15 Jun 2010, 04:17 am »
wushuliu, I've got a question... surprise!  :D
Using the standard PS, is it necessary to use a power switch (on/off) with the B1?
Battery power is a different matter of course.
wushuliu
« Reply #310 on: 15 Jun 2010, 04:41 am »
I don't. It barely draws any power.
roymail
  • Roy in TX
« Reply #311 on: 15 Jun 2010, 05:00 am »
Yes, less than 0.02 amps is not much current.  The reason I asked is I noticed that the Burson Audio Buffer has a power switch on the rear, and NP did not mention it in his paper on the B1.  Thanks!
wushuliu
« Reply #312 on: 15 Jun 2010, 06:51 am »
If all goes well I may be selling my B1 soon.  :wink:  :eyebrows:
Nick77
« Reply #313 on: 15 Jun 2010, 11:58 am »
Would you possibly be building a hot rodded B1?  :drool:
« Last Edit: 15 Jun 2010, 01:01 pm by Nick77 »
roymail
  • Roy in TX
« Reply #314 on: 15 Jun 2010, 12:59 pm »
AC, wassup?  You can tell us... we won't tell anyone!  :D
xecluded
« Reply #315 on: 15 Jun 2010, 03:30 pm »
Anand.
Thanks Anand.  I will put in my order.
wushuliu
« Reply #316 on: 15 Jun 2010, 03:39 pm »
Anand.
You forgot to mention that this is the actual size...
poseidonsvoice
« Reply #317 on: 15 Jun 2010, 05:12 pm »
:lol:
roymail
  • Roy in TX
« Reply #318 on: 15 Jun 2010, 08:43 pm »
from wushuliu,
A good test for flavoring would be the 2 1uf input caps.
How about using the Digi-Key BC2076-ND that Nelson P recommended instead of the Jantzen 1.0uF 400V Crosscap listed in the BOM?
Looks like they would also fit better on the board.  Any difference in the quality of sound?  :scratch:
wushuliu
« Reply #319 on: 15 Jun 2010, 08:55 pm »
from wushuliu,
As far as stock goes, Nelson's pick is fine. I really, really do recommend stepping up a notch with that cap and the resistors. The B1 is very responsive to the components. Though it's better to upgrade later I suppose if you're not convinced what difference it will make and want to hear it for yourself.
