0 Members and 2 Guests are viewing this topic. Read 385505 times.
If someone can explain how to upload photos I'll do my best to throw some up here.Neil
Love the case (linky?). Looks great!
Here are some photos of my B1. The chassis is a "wrap around" style, so the board is mounted to the bottom, all the wiring was done to all the connectors, and then the connectors were inserted into the chassis, and then bottom was secured to the chassis. The second set of outputs (for my sub) were wired to the first set of outputs, and everything else was wired to the board directly.Neil
Before I get my feet wet again on a B1 build or should I say, my fingers burned, I would like to know if 20 gauge hookup wire is sufficient. I'm getting parts together for the effort and have fifty feet of 20 gauge wire.
I'll have a couple extra sets of 1k and 220 ohm PRP resistors for $7 for anyone who wants to upgrade their resistors and/or lower their ouput impedance w/ the 220. This way you don't have to shell out minimum fees and ups shipping, etc. just to get them...
Do any of you guys know how to wire B1 without using the input switch,using volume controls only.
See page 12 of this thread near the bottom.
I am using an all wood enclosure,do I need to ground the unit somehow.
No you don't. Many users put them in wooden enclosures with no hum or noise.
20 gauge stranded should be fine...
Does 20ga fit into the board, holes seem pretty small. I was going to get some 24ga just to be safe but i like bigger.
