Nelson Pass B-1 preamp kit
parodielin
Re: Nelson Pass B-1 preamp kit
« Reply #200 on: 13 Apr 2010, 03:18 am »
I want to buy this volume pot suggested by wushuliu
Ebay DACT-Type Stepped Attenuator - $15 shipped
Even better AND cheaper
You can find values for 20k and higher. These are frickin' great for the money.
http://cgi.ebay.com/DACT-Type-21-Stepped-Attenuator-Volume-20K-for-PreAmp_W0QQitemZ200437532132QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2eab0205e4#ht_1476wt_1202
Could you suggest a knob that would fit this through Digi-Key? What are the key filters that would ensure the knob will fit the pot?  (I can do the search, just need to know the right filters.)
wushuliu
« Reply #201 on: 13 Apr 2010, 04:38 am »
Thanks for mentioning this. Since using them I have learned there is one caveat: as they only have 21 steps and are in fact linear I believe, there is a larger volume increase from step to step - it's not a 'smooth' increase in volume. So unless you're familiar w/ these kind of pots, I would recommend getting the Alps pot or similar from the Partsconnexion link. There are knobs for them on ebay. just search 'alps knob'.
parodielin
« Reply #202 on: 13 Apr 2010, 03:21 pm »
I am definitely not familiar into this and I was surprised to learn that volume pot could cost $300.  Geez.. Learn something new everyday.
Would this Apls work? http://www.partsconnexion.com/product7387.html 100K
How do you tell whether it is linear or not?  Would this one work better?
http://www.partsconnexion.com/product7386.html  250K
I don't know what makes the 100K and 250K different.
wushuliu
« Reply #203 on: 13 Apr 2010, 04:01 pm »
Go for the 50k...
parodielin
« Reply #204 on: 13 Apr 2010, 04:11 pm »
Go for the 50k...
I think the cost from Partsconnex is expensive adding handling and shipping fee.  I'll look for eBay...
wushuliu
« Reply #205 on: 13 Apr 2010, 07:27 pm »
Yeah, but it's a 'safe' option if you're not experienced w/ using potentiometers. The problem w/ ebay is there are a LOT of fake Alps pots out there (like anything from HK/China probably), and the first link I had actually I think may be fake so I deleted it. If you feel confident in your soldering skills I can give you a link to the VERY cheap ($3?) Panasonic EVJ pots on digikey - they are very good for the money, they just don't have too much wiggle room to solder the wire...
oh dear, AC's very flexible upload size can be a blessing and a curse. sorry!
parodielin
« Reply #206 on: 13 Apr 2010, 07:34 pm »
No, I'd not bet my solder skill to be good. ;)
How about this one from PE:
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=023-650
The shaft might be too short and I am not sure about its quality.  They have 25K too.
wushuliu
« Reply #207 on: 13 Apr 2010, 07:45 pm »
Here you go: Amb is a good site.
http://www.amb.org/shop/
The Alps 50k is listed near the bottom, just scroll down. $16 bucks and I think he
does regular usps.
parodielin
« Reply #208 on: 13 Apr 2010, 07:57 pm »
Wow, very impressive on finding this.  I know AMB and have one of their DAC.  Now off to find a volume knob, probably from AMB if they also have one.
does regular usps.
walkern
« Reply #209 on: 14 Apr 2010, 09:38 pm »
I browsed through the DIY Audio forum and found a digikey link for a knob that VERY closely matches older Nelson Pass gear knobs.  I ordered one, and it fits on the stepped potentiometer that I got via Ebay from Valab... not sure if it would fit the one you are considering.
Here is the digikey link:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=226-3016-ND
Hope this helps.
Neil
whoaru99
« Reply #210 on: 16 Apr 2010, 12:49 pm »
Anyone tried these Carli caps in the B1 for C101/C201?   http://www.madisound.com/manufacturers/carli/index.php
Also, I'm looking at these pots from DigiKey.   http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=381N503-ND
Thoughts on either/both?
wushuliu
« Reply #211 on: 16 Apr 2010, 04:07 pm »
Those are polyester caps. Perfectly usable, but as a general rule are considered inferior to polypropylene caps. Given the simplicity of the B1 design (and thus the greater influence of cap choice to sound quality), I would not recommend them.
Don't know anything about the Honeywell. The PEC pot recommended in the BOM are well regarded, and were used by Nelson for the retail B1.
wushuliu
« Reply #212 on: 16 Apr 2010, 04:19 pm »
Hope this helps.
Neil
Very cool! Thanks Neil...
parodielin
« Reply #213 on: 20 Apr 2010, 02:33 am »
Quick question on soldering PCB board.
When I solder crossover components, I'll use arligator clips as heat sinks to protect the capacitors.  I haven't seen people use this practice when soldering components onto a PCB board.  Is that b/c it's easier to heat up at PCB?
The idea should be similar so you heat up the joint and let the joint melt the solder, not the soldering iron, right?
wushuliu
« Reply #214 on: 20 Apr 2010, 05:55 am »
No, there should be no need for alligator clips at all. Yes, the heated joint melts the solder. Eutectic solder is best like the Cardas I linked in the BOM or Kester 60/40, etc. as they melt very easily. Regardless of what solder, clips should not be necessary for this application.
hth
parodielin
« Reply #215 on: 20 Apr 2010, 07:32 pm »
How did you mount the power jack?  From the picture, you seem to use glue to fix it and leave a small hole for external plug in.  How big the hole it is, like 1/4"?
wushuliu
« Reply #216 on: 21 Apr 2010, 03:31 am »
Hot glue and 1/4" hole...
parodielin
« Reply #217 on: 22 Apr 2010, 12:53 am »
Any suggested place to source interconnect cables?  I never though I'd need these but with the preamp, I need one more set. ;)
The wires from Apex Jr are excellent!
wushuliu
« Reply #218 on: 22 Apr 2010, 01:18 am »
alas, I roll my own interconnects, so I don't really have a recommendation for anything retail.
Mariusz
« Reply #219 on: 22 Apr 2010, 01:36 am »
I have one question:
- what would be the single, most influential (sound characteristic wise) part in this circuit ?
