0 Members and 1 Guest are viewing this topic. Read 68885 times.
Hi Jim,Before i got WT Amadeus GTA,i also use WT reference,so i have a WT arm protractor,and i just check the WT reference OVERHANG is 16mm,and inner null point is 69mm,outer null point is 127.2mm,hope can help you.the WT reference is great.Thanks a lot Sam. Will need those measurements soon. Speaking of the WT arm protractor, for the life of me I can't, so far, find the one I was using formerly. I wondering if it is necessary to clean out the old damping fluid and put some fresh stuff in there? Seems to me it was dusty even before I stored the table. I sure don't want to dismantle very much as my vision isn't so good. But if there is a way to start over fresh without too much trouble I would. Would you recommend doing something about the lubricant for the pivot? I don't remember checking this in the past. Do you know if there are any diagrams that show step by step directions for such things? I've downloaded the manuals for the table and arm but they don't seem very informative. At least to me.Thanks again. By the way, I'm awaiting the dust cover I'm having made.
Hi All, wonder if this thread is still active. I'm a new WTT classic owner
