Yet Another Question for James
0 Members and 1 Guest are viewing this topic. Read 4158 times.
Dilbert
« on: 25 Feb 2010, 01:22 pm »
About one year ago I ordered a new 2B SST/2 with a 17" silver faceplate. This year, I ordered another so that I could take advantage of a mono balanced configuration per channel. And, by the way, it is a tremendous improvement, not that there was anything wrong with single ended drive!
The new one looks different as it has a bevelled or chamfered edge all round the faceplate.  :( So, now they look kind of weird when stacked together. Is it safe to assume the electronics inside are the same, or has there been some sort of changes under the hood?
  • The Demo is Everything!
    • http://www.bryston.com
Re: Yet Another Question for James
« Reply #1 on: 25 Feb 2010, 01:46 pm »
Hi Dilbert,
Can you give me the 2 serial numbers and I will check for you.
james
Dilbert
« Reply #2 on: 26 Feb 2010, 12:48 am »
Hi James, thanks for your response. S/N 000411 and 000518 as you requested.
« Reply #3 on: 26 Feb 2010, 01:42 am »
Hello Mr.Tanner,
Taking this opportunity I would like to ask about the B100 and B3SST2 PRO:
1 - The current B100 integrated amp have a ''Active'' preamp or a ''Passive''(only a potentiometer and selector knob) one?
2 - The 3BSST2 PRO have a ''Adjustable Gain Control'', this is a potentiometer knob on the face plate?
Thanks for your support, Gustavo
« Reply #4 on: 26 Feb 2010, 01:59 am »
Hello Mr.Tanner,
Hi Gustavo,
1. Active
2. Gain on the pro units only
james
« Reply #5 on: 26 Feb 2010, 02:23 am »
Hi Gustavo,
1. Active
james
Thanks for your fast reply.
Iam in doubt IF the 3B PRO Gain Control is a knob on the face plate or is a dip switch on  back plate/inside etc??
Because in the Bryston site the Image showed is a 3Bsst without knob on the faceplate.
Please clear,  Gustavo
srb
« Reply #6 on: 26 Feb 2010, 02:29 am »
The gain controls (one for each channel) are flush screwdriver actuated potentiometers on the rear panel.
« Reply #7 on: 26 Feb 2010, 02:29 am »
Rear:
« Reply #8 on: 26 Feb 2010, 02:30 am »
Other than the faceplate they are identical.
james
« Reply #9 on: 26 Feb 2010, 02:44 am »
Thankyou boys, for your help.
Excuse my silly questions:
This gain control may be used as a Volume control with a no preamp setup, just a 3B and a Sony SCD-1??
Wonder IF there is any impedance prob??
Gustavo
« Reply #10 on: 26 Feb 2010, 03:02 am »
Gustavo
NO = the gain control only has adjustments from 29dB down to 13dB
james
« Reply #11 on: 26 Feb 2010, 03:10 am »
james
OK, It is the 1V or 2V sensitivity control, I already see a image of this swith.
Thanks for your help, Gustavo
Dilbert
« Reply #12 on: 26 Feb 2010, 07:04 pm »
Uh, I think the pro version also has a potentiometer. Now, can we get back to my question? :nono:
Stu Pitt
« Reply #13 on: 26 Feb 2010, 09:16 pm »
james
You may have missed it in the hijackness.
« Reply #14 on: 26 Feb 2010, 10:08 pm »
Excuse me the out of topic questions.
Gustavo
Dilbert
« Reply #15 on: 27 Feb 2010, 02:57 am »
Yeah, maybe...anyway, no problem. Thanks James, for the info. I will likely order another to match cosmetically -  I can probably use the older unit for another application.
For those interested, the 2B SST/2 in a balanced config is worth trying out (350 W/8Ohms, although I only need 50). I am using it in high pass duty (>290 Hz, 8 Ohms nominal) in a triamp set up and I am extremely impressed.
Dilbert
« Reply #16 on: 27 Feb 2010, 02:59 am »
Gustavo
No worries. :D
gdbalp
« Reply #17 on: 9 Mar 2010, 12:04 am »
James,
I have one more question for potential upgrades to 9B-SST amplifiers.  I know you have said in the past that it is not economical to upgrade, but 9B-SST is modular in design and could be dismantled easily?  Also, Bryston provides upgrades from 9B-ST to 9B-SST, so SST to SST^2 would just continue this tradition...
As you can tell, I am trying to stay current with Bryston product lines...
Ciao,
Luigi
« Reply #18 on: 9 Mar 2010, 03:45 am »
James,
Ciao,
Luigi
Hi,
By the time you replace 5 complete channels in the old 9B you would have more invested than selling the older 9B and using that money to purchase a new 9B.
james
