New Media Room Journal
0 Members and 1 Guest are viewing this topic. Read 6900 times.
Rob Babcock
Re: New Media Room Journal
« Reply #20 on: 9 Sep 2010, 09:34 am »
I think we need more pics! :eyebrows:
HT cOz
« Reply #21 on: 9 Sep 2010, 01:03 pm »
Here is the latest from the first post...
To get an idea of scale those pieces of rockwool are 2' x 4'...
HT cOz
« Reply #22 on: 15 Sep 2010, 01:02 pm »
The floors are coming along.  I choose to dye them using Transtint mixed with alcohol.  The color is Dark Walnut and it is very dark indeed.  I do plan on repainting the room the contrast will not be so great in the future.  I am using Waterlox to finish the floors and provide the protective coat.
Next I will choose which color to cover the boxes with atsacoustics.com/item--Microsuede-Fabric-60-inch-wide--1027.html  I’m just not sure which way to go on this part and need to order some samples.  I will order one additional box of 2” Rockwool to finish the ceiling box and add the rest to the front box making it 6”.
After that I will need to order my acoustically transparent screen.  After that I have to build my speakers….
HT cOz
« Reply #23 on: 8 Oct 2010, 02:28 am »
Finished the floors!!!  :D
Thanks for looking
HT cOz
« Reply #24 on: 17 Apr 2011, 10:08 pm »
The project is finished.  I am very happy with the results.
