Insight Integrated Amp Questions
0 Members and 1 Guest are viewing this topic. Read 2255 times.
Birdbrain
« on: 16 Feb 2010, 02:46 am »
Can you add phono circuits? Tape buffer option? Phase inverter?
A Double Integrated with those three options would be the cat's meow.
avahifi
    • http://www.avahifi.com
Re: Insight Integrated Amp Questions
« Reply #1 on: 16 Feb 2010, 09:58 pm »
The double die option is available on the Insight Control Amplifier, but not phono circuits or tape buffers.
This is a unique product, with no active preamp section at all, it uses a high gain version of the Insight control amp circuits instead.  Thus there is no low voltage power supply available for the other options.
Frank Van Alstine
JHC
« Reply #2 on: 2 Mar 2010, 08:21 pm »
I hope this stays around. I've been interested in simplifying my set up and had been contemplating Creek Audio, Peachtree, Music Hall or some other integrated. Since I'm jsut running flac files to a Squeezebox, I've no need for a phono section. Maybe another line in case I use my CD player again for some reason. But for now, I'll just keep "contemplating".
Birdbrain
« Reply #3 on: 18 May 2010, 12:35 am »
What about the phase inverter?
rlee8394
« Reply #4 on: 18 May 2010, 08:08 pm »
Not applicable with an integrated amp.
