Anyone ever use this
0 Members and 1 Guest are viewing this topic. Read 1987 times.
mosawdust
« on: 15 Feb 2010, 11:22 pm »
I was lookig at this as a little cheaper alternative to Dynamat to line the woofer baskets. The modeling clay just seems like one heck of a lot of work when your looking a 4-15's & 2-12's.
http://www.mcmaster.com/#9709t26/=5u0amb
Russtafarian
  • Typical reaction to the music I play
Re: Anyone ever use this
« Reply #1 on: 16 Feb 2010, 07:49 pm »
I used this Quick Roof stuff from Home Depot inside my RM30 cabinets and on woofer baskets.  Works like dynamat for a lot less money.
http://www.homedepot.com/Building-Materials-Roofing-Gutters-Roofing/h_d1/N-5yc1vZ1xhcZaq7m/R-100594339/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Russ
mosawdust
« Reply #2 on: 16 Feb 2010, 11:15 pm »
Russ
Did you have any problems or issues with odor or outgassing? Is it tar based? I looked at the link but it doesn't really say much.
Brian
SpeakerDoc
« Reply #3 on: 7 Aug 2010, 03:09 pm »
Brian
This .pdf might help answer that:
http://www.cofair.com/pdf/msds/QRMat%20Safe%20Data.pdf
http://www.cofair.com/msds.aspx
