Wanted!! Sound Anchor (or other) Stands for ACI Sapphire XL
0 Members and 1 Guest are viewing this topic. Read 1758 times.
Cliff B.
The ad for the speakers certainly was productive so I might as well try doing the same for the stands. I need a pair of stands for the ACI Sapphire XL's and would prefer the ones originally sold by ACI but will consider others if they are of good quality and can be filled with sand.
Cliff
bpape
    • Sensible Sound Solutions
Re: Wanted!! Sound Anchor (or other) Stands for ACI Sapphire XL
« Reply #1 on: 12 Feb 2010, 07:34 pm »
If you can't find a used pair, you could always just contact Sound Anchors directly.  I'm sure they'd make you a pair.
Bryan
Hugh
    • Angel City Audio
« Reply #2 on: 12 Feb 2010, 07:38 pm »
Have you considered our Onix stands?
http://www.audiocircle.com/index.php?topic=70130.60
Cliff B.
« Reply #3 on: 12 Feb 2010, 08:24 pm »
Hugh,
Nice looking stands. Are they made of steel and can they be filled with sand/shot?
thanks,
Cliff
DWayland
« Reply #4 on: 12 Feb 2010, 09:01 pm »
Hugh,
thanks,
Cliff
Greetings Cliff,
In answer to your question, they are made of MDF and are totally solid.  Meaning, they are not mass loadable.
The base is quite heavy though, as there is a steel plate sandwiched between the MDF layers, which adds a good deal of stability.
Here is a link to some more pictures of the stands in Satin Black
http://www.flickr.com/photos/dwayland/sets/72157622756330931/show/
Derek
kolledog
  • Guest
« Reply #5 on: 26 Mar 2010, 12:46 pm »
there is a pair of sound anchor stands for sapphires on EBAY right now
