Counting down!
0 Members and 1 Guest are viewing this topic. Read 11996 times.
JohnR
Re: Counting down!
« Reply #40 on: 6 Mar 2010, 11:33 am »
They're back up.  Lost 1 order... but we'd shipped it already.  It's all good.  Lots of amps shipping... good stuff.  We even shipped yours John R!
Awesome, Seth, thank you! - obviously it takes longer for me but I'll keep an eye out!! It's stopped raining for now, at least :thumb:
JohnR
Re: Counting down!
« Reply #41 on: 10 Mar 2010, 12:15 pm »
Got them today. That's pretty quick for regular post. Haven't had a chance to plug any of them in yet. I seem to be inundated with amps :lol:
madawasca mike
Re: Counting down!
« Reply #42 on: 11 Mar 2010, 07:39 pm »
Picked mine up at the post office today (Toronto, Ontario) Hopefully unpack it tonite and start the burn in.
No border problems, fees etc. FANTASTIC start!  :drool:
virtue
  • Making audio lovers audiophiles
    • Virtue Audio
Re: Soft-start / 3A fuses are insufficient
« Reply #43 on: 11 Mar 2010, 07:58 pm »
I've received a few panic-stricken emails from folks who plugged batteries or linear supplies and "blew out" their amps.  In fact, the standard 3A fuses were blown, that's all.
On the original amps, anything above 3A would have been a "problem."  In fact, these 3A fuses sometimes survived the 4.3A that the 30v/130w could deliver.  Not a chance with the high-current supplies.
Upon reflection, we should have bought and sent 8A or 10A fuses out with the soft-starts.  You're basically on your own to find these fuses and if anyone would like to post sources here to help other customers, please do.  It wouldn't make sense for me to sell such a low-cost item because I'd need to pass along substantial order handling fees that I pay...
If you want to go crazy on fuses, a number of firms out there will sell you a single, high conductivity one for $50+.  Some reputable "ears" have told me that they actually do make a sonic difference but I'm not yet at the point where I will sell such a tiny thing for that kind of money.
Seth
PSB Guy
Re: Counting down!
« Reply #44 on: 11 Mar 2010, 08:13 pm »
One of probably many sources:
http://www.electronicplus.com/
10 AMP @ 250 VOLTS GDC 5mm x 20mm SLOW BLOW FUSE - $2.25 (US)
Cheers
madawasca mike
Re: Counting down!
« Reply #45 on: 11 Mar 2010, 08:47 pm »
seth, does the fuse swap  out also refer to the V1 as well as the V1.2? I'm com-fused!
virtue
    • Virtue Audio
Re: Counting down!
« Reply #46 on: 11 Mar 2010, 08:59 pm »
They are rated higher.  I forget the details.  Someone please post when you get your ONE.2.  I haven't got mine yet!
antonio
Re: Counting down!
« Reply #47 on: 11 Mar 2010, 10:11 pm »
seth,
also sensation needs to change fuse before use with a with power supply antek 10A?
if yes, is there a picture that shows how do it?
thanks
antonio
virtue
    • Virtue Audio
Re: Counting down!
« Reply #48 on: 12 Mar 2010, 01:03 am »
Nope... I think it's all good.  Sensation is much easier to get in/out than the little guy.  The top-shelf is trivial to slide out!
Xcalibur
Re: Counting down!
« Reply #49 on: 12 Mar 2010, 02:39 am »
Did the original TWO have a 3A fuse as well?  If so I apparently don't push mine hard enough because I've never changed a fuse and it's running the 30v/130w supply.
virtue
    • Virtue Audio
Re: Counting down!
« Reply #50 on: 12 Mar 2010, 07:02 am »
We put 5A or 7A fuses in most of the TWOs.  That may be enough for a while.
Xcalibur
Re: Counting down!
« Reply #51 on: 12 Mar 2010, 07:08 am »
That makes sense.  If the switching supply can only deliver 4.3A even a 5A fuse should be sufficient then.
antonio
Re: Counting down!
« Reply #52 on: 12 Mar 2010, 03:53 pm »
for an ampli, slow or fast blow fuse? i think fast. that's correct?
antonio
PSB Guy
Re: Counting down!
« Reply #53 on: 12 Mar 2010, 05:39 pm »
Slow blow, Antonio.
nmolenbeek
Re: Counting down!
« Reply #54 on: 15 Mar 2010, 01:34 pm »
Mhmm. still waiting on the amp. Customs sure takes its time. Or did thay love it so much that the have it playing at the customs.
    Detailed Results:
   Into Foreign Customs, March 03, 2010, 8:18 am, NETHERLANDS
   Arrived Abroad, March 03, 2010, 8:18 am, NETHERLANDS
   International Dispatch, February 27, 2010, 10:04 am, ISC NEW YORK NY(USPS)
   Arrival
   Processed through Sort Facility, February 27, 2010, 2:45 am, JAMAICA, NY 11499
   Electronic Shipping Info Received, February 26, 2010
Hopefully it will arrive this week!!
