0 Members and 1 Guest are viewing this topic. Read 8008 times.
I wouldn't do without my RR-77! That being said, I wonder how 2 can actually work, being that they each produce a 7.83hz pulse (the hum of the earth, for simplicity sake). If the pulse of the two are not clocked together how does the Schumann effect not get mucked up??
After I ordered, but before I received, my RR-77 I tried this less expensive one.http://www.kellyresearchtech.com/elf.htmlDidn't work. We theorized my room was too large for it...but after chatting with them I secretly put it under the bed of one of my sons. He complained of sleep issues, but magically after that did not.
I got the full sized one, but still no effect in my 15.25' x 22.9' x 10' room. They said it was more sized for 8 x 10.
Interesting.Does anyone know if the Quantum Research devices were Shumann resonators?I got one 5-6 years ago and it improved my stereo and TV. Everything was clearer, cleaner, you name it. I was told me it generated a frequency that combated EMI and RFI. It still works: if I put my ear right up to it, I can hear it gently humming. I have it at the base of my TV rack which is right next to my stereo rack.nonoise
I've documented my findings on the RR -77 Shumann on numerous occasions - it didn't work for me. I used the height recommendations and tried a blind AB with it on and off, apparently we all have different degrees of sensitivity to the generator. One of the questions raised was the psu being to weak for the RR-77, has this now been upgraded? If it has I would be interested in giving it another demo.....
Hi Phil, an upgraded power supply does help a lot for me but I didn't need it to notice the difference when using the RR-77 as-is. I doubt an upgraded power supply or even multipe units would do anything for you myself. This product simply doesn't work for everyone. Cheers,Robin
