Soundsilver cables
Re: Soundsilver cables
« Reply #20 on: 16 Jul 2010, 11:45 am »
Bill
Buy a pair of the Mac's and I'll lend you my soundsilver cable
I have 4 pair of the MAC's Evan Do you own any MAC's
etcarroll
« Reply #21 on: 16 Jul 2010, 01:35 pm »
Stewart -
Good luck with the new venture.
Was curious why exactly you feel the Switchcrafts are better constructed than the Neutrick?
Gene
I just wanted to thank Evan for both purchasing the interconnects and posting his favorable review.
I  also want to add some clarification regarding the copper ground.
The wire is actually magnet wire which has an enamel or sometimes polyurethane coating which acts as the insulator, so it is quite durable. Also, if the Switchcraft connectors are a problem I can probably swap them out for Neutriks for a few extra dollars. However, I feel the Switchcraft has considerably better construction and sound. Thanks again Evan you are truly a good man.
Regards to all Stewart @ Soundsilver
evan1
« Reply #22 on: 16 Jul 2010, 11:25 pm »
No, but I had a Big Mac for lunch
soundsilver
« Reply #23 on: 16 Jul 2010, 11:52 pm »
Gene,
I have used both the lower priced Neutrik and the Switchcraft, and I
find that the solder cups are much better, the insulator is better, the
plating is better, and they appear to be less brassy.
Also, being that I use multiple signal conductors in several of my designs I feel
that the Switchcrafts are better suited to these particular applications.
These of course are my personal opinions, and therefore, are very subjective.
Thanks and regards, Stewart
etcarroll
« Reply #24 on: 16 Jul 2010, 11:59 pm »
Gotcha.
So, you're not talking about the Neutrik Profi plugs then.
Rocket
« Reply #25 on: 17 Jul 2010, 12:38 am »
Hi Stewart,
I'm considering getting 2 pairs of 4 foot interconnects from you and I'm wondering what shipping is to Australia?
Rod
soundsilver
« Reply #26 on: 17 Jul 2010, 01:37 am »
Hello Rod,
Thank you for the inquiry.
The most cost effective way to send the cables would be USPS priority mail,
and the cost would be USD 15.00 for the shipping.
I have done so previously, and it took approximately 7 business days to arrive in Melbourne.
If you wish to contact me directly for more information please send your
correspondence to: [email protected]
Thanks and regards, Stewart Prior @ Soundsilver
Rocket
« Reply #27 on: 17 Jul 2010, 08:51 am »
Hi Stewart,
I'll send you an email by the end of next week.  I am finally receiving my ampzilla monoblocks next week and I think I need a pair of ic's 4 foot in length.  My current one's are .75metre.
I'll email once I ascertain the length that I require.
Thanks for producing an affordable ic.
Regards
Rod
guest1632
  • Guest
« Reply #28 on: 17 Jul 2010, 10:53 am »
Hello Rod,
Hi Stewart,
Are your cables directional, like using a fantom ground ETC? If so, how are you marking them?
Ray Bronk
soundsilver
« Reply #29 on: 17 Jul 2010, 01:27 pm »
Hello Rod,
Thank you for the question. My cables are non-directional. You may contact medirectly at: [email protected] in the event you have any other questions. regards, Stewart @ Soundsilver
Barry_NJ
  • So much media... So little time...
« Reply #30 on: 12 Nov 2010, 12:54 am »
Well it's been a while since I received my cables, and I figure I should post my follow-up...
I compared the SoundSilver cables to a set of $500 Luminous Audio Synchestra Reference Interconnects that someone had loaned me at the time I received them. The SoundSilver cables were a bit more sibilant than the Luminous, but not annoyingly so, I just noticed the difference with that aspect of the sound. The bass is both weighty and well defined, and the mids are clean and articulate. The SoundSilver easily bettered the Monster 850i interconnects I replaced, offering far more clarity and life in their presentation of the recorded event. I'm planning on getting some more  :thumb:
guest1632
  • Guest
« Reply #31 on: 13 Dec 2010, 04:03 pm »
Please define "sibilant." I am not sure what you mean by that term.
Ray
guest1632
  • Guest
« Reply #32 on: 13 Dec 2010, 04:06 pm »
Hello Rod,
Hi Stewart,
Just looked on the link for the Audiogon, and it is gone. So do you have any updates? types, price ETC?
Ray Bronk
soundsilver
« Reply #33 on: 13 Dec 2010, 04:47 pm »
Hello Ray,
Nice to hear from you again. I currently have four classifed advertisements of Audigon. Just type in soundsilver in the search field on the home page, and they will be displayed.
Here are 2 of the links:
http://cgi.audiogon.com/cgi-bin/cl.pl?cablintr&1295238706&/Soundsilver-Dual-Silver-Two-so
http://cgi.audiogon.com/cgi-bin/cl.pl?cablintr&1295039475&/Soundsilver-Trilogy--Three-pur
Take care, and if you wish any additional information please contact me at [email protected]
Stewart
Barry_NJ
« Reply #34 on: 14 Dec 2010, 12:49 am »
Ray
http://dictionary.reference.com/browse/sibilant
Basically that 'S' sounds are a bit more pronounced, sounds like close miked vocals accentuating breath sounds, etc.
putz
« Reply #35 on: 14 Dec 2010, 02:20 am »
Anyone ever compare the Soundsilvers with the Macs?
Do these cables require break in? Mac recommends a pretty long period for theirs.
Mariusz
« Reply #36 on: 14 Dec 2010, 03:02 am »
No MAC but I have Morrow Audio, Art Audio, Virtue Audio, AR Stereophile "recommended", some DIY cables cooked up by our fellow AC member, and ofcause Sound Silver interconnects.
Stay tuned for update on these cables.........
Impressions coming soon.
Mariusz
guest1632
  • Guest
« Reply #37 on: 14 Dec 2010, 04:15 am »
Mariusz
Hi Mariusz,
Are you gonna check out all three types, single, dual and tripple?
Ray
Mariusz
« Reply #38 on: 14 Dec 2010, 05:16 am »
Hi Mariusz,
Ray
I believe triple wire ones were send for evaluation.
Mariusz
