0 Members and 1 Guest are viewing this topic. Read 20382 times.
When the AVA web sight says the 240/2 delivers 125W/ch, does that mean into an 8ohm load? So if your speakers are 4ohm, do you double that to understand the power rating?
If I just got the Insight SL preamp and the Insight 240/2, and plugged my SACD player into my preamp using the analog in/outs would I be giving up something significant by not having the hybrid premap with the better integrated DAC? AND...when I plug my iPod into the USB plug on my SACD player, is the SACD player's DAC working or is it the iPod DAC? Thanks again. This is really helpful to me!!
OR is this unit you recommended simply an AVA preamp with an even better high end built in DAC?
Bigload, I have a Marantz CD5001, and the analog output is crap compared to my DACs' analog outputs, but I only paid 300.00 for the thing. Maybe you have a high end SACD player.Why are you called Bigload, if you don't mind me asking?BTW, anyone interest in a minty Marantz CD5001?
No, this unit is not better because of the built-in DAC, just less expensive. I don't know your budget. I you want to do it up really nice, you could get an AVA Vision DAC, an AVA AvaStar preamp with a built-in phase inverter bridge, and two AVA Ultra Double 550 amps, running in mono, each producing about 1000 watts of sweet, AVA muscle. Some might think that is overkill. Don't get caught up comparing the specs of different electronic components. The specs tell you NOTHING (not yelling here) about the quality or sound. While a person often gets what they pay for, with AVA and Salk, you will get a lot more than you pay for.
Well, I guess my budget keeps growing the better stuff sounds. Heck I started out thinking about a $1400 AVA integrated unit, or some other less expensive stuff. Now I am thinking about some really sweet sounding stuff you guys have suggested that gets me up around $3500.
Do you have a two-channel system or an integrated HT system?
I'm pretty sure the Marantz has a good DAC in it so I think you will be OK
