A question about digital I/O
0 Members and 1 Guest are viewing this topic. Read 1701 times.
JakeJ
« on: 5 Feb 2010, 05:01 pm »
Hi all,
This may not have been the right circle so if needs to be moved that's cool.
Which I/O is the most preferable?
I recently upgraded to a separate DAC/transport kit.  I didn't really consider I/O when I was shopping and ended up with a transport that has Superlink (proprietary?), Toslink, Coax, and AES/EBU outputs and a DAC that has Coax, AES/EBU, I2S, and Toslink.  So which is the best interface?
TIA,
JakeJ
audioengr
Re: A question about digital I/O
« Reply #1 on: 5 Feb 2010, 08:08 pm »
Hi all,
TIA,
JakeJ
For the lowest jitter, the computer interface should be asynchronous.  This can be PCI, Firewire or USB.  My new 192 USB interface on the Pace-Car USB is async.  With a properly designed async interface, the cable is unimportant, so this saves money.
The DAC interface for lowest jitter, at least with my products is the I2S interface, but my S/PDIF is also extremely low-jitter.  In most systems, you will not hear a difference.  The cable to the DAC is critical.  Buy the best you can find in 1.5m length.
Steve N.
Empirical Audio
JakeJ
« Reply #2 on: 5 Feb 2010, 08:56 pm »
Thanks, Steve.  I was under the impression that I2S was better because the data and clock streams were separated thus providing lower jitter.  Obviously if S/PDIF is done properly it isn't an issue.
audioengr
« Reply #3 on: 5 Feb 2010, 09:38 pm »
Correct.  Unfortunately, most manufacturers don't do a good job with S/PDIF.  I have modded dozens of products to fix them in the last 10 years.
Steve N.
