Help - need replacement part
Erik Williams
  • Guest
« on: 5 Feb 2010, 01:53 pm »
Need a mid-range woofer for a Sapphire XL. Speaker is only 1 year old and only the tweeter works. I cannot figure out who to call, contact, to get one.
Finally got a pro into my home to check out why my receiver was 'tripping' and has been when run loud since I first hooked it up. Turns out, the Sapphire XL was the curlprit.
Erik
860-805-3243
Erik Williams
  • Guest
Re: Help - need replacement part
« Reply #1 on: 5 Feb 2010, 02:44 pm »
If no replacement parts exist...looking to buy an ESSENCE center channel. I am currently using a third Sapphire XL for a center channel.
Any other ACI suggestions for a Center?
Erik
bpape
    • Sensible Sound Solutions
« Reply #2 on: 5 Feb 2010, 02:47 pm »
Mike will be able to provide you with the make/model of the replacement driver.  It's a Scan Speak just don't remember the model number.
Bryan
Mike Dzurko
« Reply #3 on: 5 Feb 2010, 05:48 pm »
That Scanspeak is readily available. I'll PM you the part # when I get home tonight. If I forget, just PM me.
Erik Williams
  • Guest
« Reply #4 on: 5 Feb 2010, 06:03 pm »
Thanks Mike.
Congrats on the retirement. Should I assume all warranties are now void as well?
Erik Williams
  • Guest
« Reply #5 on: 5 Feb 2010, 08:40 pm »
My email is [email protected]
Mike Dzurko
« Reply #6 on: 7 Feb 2010, 01:31 pm »
