Testing opamps
Raj
Testing opamps
« Reply #20 on: 29 Sep 2004, 06:01 pm »
HI,
I recently tried ad817 in the mos 250, and it seems to work ok. Bearing in mind that I run the output mosfet pair at a quiescent curent in excess of 560ma, and also have the 390r/82r mods in place. Well in comparison to ad825 it just sounds much more 'right', more fluid, natural, the detail complements the music and is not in your face like the ad825, also the resolution on edges remains focused but is not as edgy or harsh. The most interesting aspect of it's introduction is the resolution of the system stays more constant during complex passages. I havn't tried anything faster than this opamp in the mos250 yet. The ad817 is quite suitable due to it's high but not excessive bandwidth, fast settling time and slew rate of around 300v/us. The other 2 opamps I have in mind are ths4061 with slew rate of 400v/us, but a high bandwidth of 180mhz, or ad818 which slews at around 500v/us and has a bandwidth of 120mhz or so, but I am a little weary of the chance of oscillation. The good thing with ad817, ad847 and ad818 is that they are available in standard dil style, so that adaptor sockets aren't needed.
Raja
fmoya
    • http://www.eucor-online.com/altavoces
AD844 & AD845
« Reply #21 on: 28 Oct 2004, 11:59 am »
Has anyone thied those ones? Could they be used on the MOS125 or the Buffer Amplifier? I'm using now the AD8610 on the Buffer Amplifier without coupling capacitor and the sound is superb. I have the AD8620 intalled on my modified Philips CD723 too and OPA627 on the MOS125. The sound is fantastic, but once you start investigating you can't stop...
Regards.
