Please be careful with mods!
0 Members and 1 Guest are viewing this topic. Read 6069 times.
ctviggen
Re: Please be careful with mods!
« Reply #20 on: 3 Feb 2010, 10:20 pm »
Many brands of equipment that have only a 2 conductor cord do not have the chassis grounded. I have a brand new Onkyo T-4555 HD tuner, Sony XDR-F1HD HD tuner, Marantz CD5400 CD player, and every turntable that I have, without a grounded chassis. In Frank's case, the line leg of the 120 volt hot side goes immediately into a line fuse as I'm sure is the case with all other 2 wire components. The ground is simply not necessary, even with a metal case (as all components I have mentioned) and introducing a ground to the case, while not "unsafe" may cause noise or ground loops typically associated with 3 prong components. I am simply amazed how many people praise Frank's equipment, but then chastise him for not offering an unnecessary grounded scheme.
If you will notice on a polarized outlet, how many think the wider vertical slot on the left is the hot? Well, it's not, it's the neutral. Then I wonder how many DIYer's have the neutral side fused and the hot side unguarded?
Wayner  :?
You can still get ground loops with an "ungrounded" chassis. Also, grounding the chassis helps to prevent RF from entering or leaving the device.  Of course, whether this is a benefit or not is a function of many variables, the main one being the device itself.
The only item I own that does not have a grounded plug is a AV receiver.  Pretty much everything else has a grounded plug.  (We're talking audio gear, here.)
