BP 26
0 Members and 1 Guest are viewing this topic. Read 1497 times.
gordon
BP 26
« on: 29 Jan 2010, 03:52 am »
I am interested in upgrading from a BP25DA to a BP26. I need to place the power supply approx 2 metres from the pre-amp, is there a limit on the length of connector between the mps2 and bp26??
cascais
Re: BP 26
« Reply #1 on: 30 Jan 2010, 04:32 pm »
I needed to separate the BP26 from the power supply since it was inducing hum in my cartridge. The power supply is located at least a meter from the preamp. In fact I think that the further you get the power supply away from the preamp, the better. You probably are limited only by the length of the connector cable. By the way, the BP26 is a great preamp.
  • The Demo is Everything!
    • http://www.bryston.com
Re: BP 26
« Reply #2 on: 30 Jan 2010, 04:34 pm »
Yes we can do a custom length cable for you and 2 to 3 times longer should not present any issues.
james
werd
Re: BP 26
« Reply #3 on: 30 Jan 2010, 05:20 pm »
james
I suppose you can do a .5 mtr too?
Re: BP 26
« Reply #4 on: 30 Jan 2010, 05:26 pm »
Hi werd,
YUP - no problem.
james
