0 Members and 1 Guest are viewing this topic. Read 32753 times.
iPad (don't like the name; sounds like a feminine hygiene product) to take a picture.
Can you name a single one that this one does that neither of those can?
(tall) enough to house USB ports, and use a pruned OS X install
an sd slot it
And how many of them carry around all three at the same time?
USB port on the left, available from Apple. To keep battery life up they needed to use a StrongARM (that's what an A4 is) -- same as iPhone, so iPhone OS. When iPhone gets multi-tasking so will iPad.dave
a Unix machine with a one button mouse.
iPad. From the people that gave you a Unix machine with a one button mouse.
Not sure what the graphic is you included. I'm guessing an adapter to plug into the big multi-pin port found on iPods, etc?My point about the size of the device is that they hobbled functionality in the name of keeping the thickness down to 1/2 an inch. They stuck w/ A4 because it allows them to stay with software across the iPhone/iPod Touch. Magical _and_ revolutionary? Um, right. Whatever.If Apple had the thickness of iPad match the base of a Macbook Pro (call it 3/4 of an inch), there would be plenty of room for all of the grunt in a MacBook Air (if they wanted to go that far). Battery life would be fine. There is no engineering problem here. It's all about Job-o and his mania against anything that smells like a Newton.iPad. From the people that gave you a Unix machine with a one button mouse.
Weird...my "one button" mouse has two buttons??
Size and weight vs an adapter........hmmmmm. I'll take it skinny. If I'm going on a trip where I'll need crunching power, it's the MBP that will get packed anyhow. Still, I'll wait for the second or third generation to make sure the kinks are all out including remote desktop.
I don't know how old your Mac mouse is, but, a Mac mouse with more than one button (read, a "left click") is a relatively new thing....you could simply plug in a standard USB PC mouse with no need for driver installation.
As an aside, a friend sent me a link to an old thread on the Macrumors forum discussing the original iPod announcement. Some choice quotes:"Doesn't a Mac with a CDR undermine the need for most of this? All that's left is the number of songs you can play and the ability to listen to all of them with headphones anywhere. Do I really need ALL my songs ALL the time?...won't last, another Cube"."Why oh why would they do this?! It's so wrong! It's so stupid!""The Reality Distiortion Field™ is starting to warp Steve's mind if he thinks for one second that this thing is gonna take off." Not saying the iPad will have the same success, but still...
I guess I'm showing my age. Having computing experience that pre-dates the Osborne Era, I don't have a problem carrying my 15" MBP with whatever else I need.
