0 Members and 1 Guest are viewing this topic. Read 13805 times.
Alan and dibber, I look forward to hearing more of your thoughts on the systems that you have. I'm especially curious about the effects of removing the preamp from your system. I've never been much of a source straight to the amp kind of guy or passive pre type, because I've found an active pre important for giving me the dynamics and oomph I was looking for in my system. Alan, how have you found the IK Multimedia ARC software to implement on your own?
So why on earth would I invest in a highly manipulated digital system like the orpheus/emerald physcis CS2.3? Here's why. I believe this system is better at replicating the original recording than any system on the market at any price right now. It, for the first time, allows lovers of analog an even superior experience to what they can enjoy with a $100,000 plus state-of-the-art analog system. I get that I just made a ridiculously bold statement. But here's the thing. I believe this orpheus/CS2.3 system is the best system on the market for playing 24 bit .wav files. It is, more-or-less, what is used (hardware wise) in modern recording studios for music playback. On top of that, it uses quite sophisticated software to eliminate room and timing distortion, allowing for musical presentation very similar to that in the sound-proofed recording studio even if your room is big and/or odd shaped without sound dampening. If that offends the purist in you ... you'll be relieved to know that I was a non-believer too. But here's the thing. When you set aside the analog religion and really listen a top-quality digital 24 bit system with your ears and eyes closed, you too will have the revelation. It is simply superior to the best analog systems. It shouldn't be, from the purist point of view. But it is.
Dibber,Do you have the system in place?How does it sound?Thanks,David
Live recordings often sounds better than studio recordings.
I like vinyl.But I think high def digital really is wonderful.I obviously can't make a controlled comparison in this instance, but there is a guy who operates as HDTT (high definition tape transfers), who takes commercial tape recordings (analogue of course!) of special performances or recordings (not even master tapes) and uses state of the art digitizing gear to come up with up to 24/192. I've downloaded some 24/96 files, which I play from a hard drive, through a Dacmagic (just converts digital spdif to digital RCA- no loss), straight into the digital input of the DEQX. The only deficiency is that sometimes the original tape recordings saturate.The result is some of the best recorded music I have heard.
Have you ever heard a master tape dub on reel to reel?
Think these HDTT performances sound better than the tapes they are copied from?
