High Sensitivity Design
0 Members and 1 Guest are viewing this topic. Read 10511 times.
Rick Craig
  • Selah Audio
    • http://www.selahaudio.com
Re: High Sensitivity Design
« Reply #20 on: 8 Feb 2010, 07:30 pm »
[quoteResponse curves look good for the woofer. Sensitivity is 96.5db which is in line with what I expected. With the normal amount of crossover compensation to flatten out the upper midrange a system sensitivity of 93-94db is possible.]
What would the impedance window look like?
That really depends on the crossover, most likely in the 6-8 ohm range. If you have a high output impedance amplifier (SET,etc) a conjugate network can be added to flatten the load.
X5nut44
« Reply #21 on: 9 Feb 2010, 05:20 am »
Probably closer to 50-55hz depending on the tuning of a ported enclosure. The fs of the woofer is 33hz so you'll still have decent extension below the -3db point.
Sounds good.  Will your demo be a sealed or ported enclosure?
Rick Craig
  • Selah Audio
« Reply #22 on: 9 Feb 2010, 02:16 pm »
Not sure yet what exactly we'll be doing but  I'll post here when I have more information.
lokie
« Reply #23 on: 9 Feb 2010, 08:20 pm »
What's the size of the bass cabinets you are considering?
Rick Craig
  • Selah Audio
« Reply #24 on: 9 Feb 2010, 08:49 pm »
Sorry - can't give out any information on that until we finalize the design.
lokie
« Reply #25 on: 10 Feb 2010, 02:43 pm »
Rick,
Do you have any comments/opinions etc. of the Fostex T500AmkII tweeter?
Rick Craig
  • Selah Audio
« Reply #26 on: 10 Feb 2010, 03:07 pm »
Rick,
I don't think I've listened to it but some of the systems I've seen it in are terribly flawed. Integration isn't going to be very good when adding that tweeter to woofers 6" and larger. Off-axis response will suffer as well.
lokie
« Reply #27 on: 11 Feb 2010, 12:55 pm »
Why 6"?
I have the impression that you would make that comment about all horns.
Rick Craig
  • Selah Audio
« Reply #28 on: 11 Feb 2010, 02:39 pm »
Why 6"?
The 6" and larger cones don't have wide enough dispersion to cross high enough for the Fostex tweeter. Many of the woofers also have upper end breakups that require a lower crossover point.
 I don't have a prejudice against horns as long as they are properly implemented.
lokie
« Reply #29 on: 11 Feb 2010, 03:39 pm »
I suppose the reason I stated that is because I don't recall you ever using horns in any of your designs. Any example of horns that are properly implemented?
Rick Craig
  • Selah Audio
« Reply #30 on: 11 Feb 2010, 07:45 pm »
I don't receive many requests for designs using horns and high sensitivity has never been one of my priorities except for array designs. I've worked with horns in pro audio systems from other companies that worked well and some that weren't so good.
X5nut44
« Reply #31 on: 2 Mar 2010, 04:59 am »
Rick,
How well will the TD15M woofer work with a passive radiator?  I know the enclosure will have to be twice the size but just curious. :eyebrows:
Rick Craig
  • Selah Audio
« Reply #32 on: 2 Mar 2010, 03:47 pm »
Rick,
Sure you could use a PR but a large port would be fine.
Rick Craig
  • Selah Audio
« Reply #33 on: 23 Mar 2010, 08:50 pm »
Our customer decided to go in a different direction so I have two drivers available for sale. The woofer is an Acoustic Elegance TD15M (Apollo motor upgrade) and the ribbon tweeter is the Raven Line Source. I can also source additional drivers and design a kit (no cabinets) or an assembled pair with custom cabinets. Please email or PM here if you're interested.
