0 Members and 4 Guests are viewing this topic. Read 1219203 times.
Use an aluminum case.
Ya think maybe? Or stamped steel with lots of vent area for better cooling? Easy enough to mount a wood "dress panel" to hide the sordid reality. I suppose copper screen or a "bird cage" of 1/4 inch hardware cloth (with mounting plates for input and output connectors) would also work . . .
Well, being that I'm making aluminum cases for these, yes, I'd say aluminum. Mine will have vents in the top rear for cooling.
Could the top rear vents be accompanied by bottom or side intake vents so that there is some kind of convection "air flow"? Steve
It will not have side vents...Tom said the way I have it, is perfect for venting. Also, there are holes on the bottom so you will get airflow.
+2Since my box is all wood. I was thinking of using copper or aluminum for interior walls. Solving shielding and grounding issues. Lowe's got thin sheets in rolls (roofing supplies) but it is like $40 per roll and lots of it. Anybody got different source ???Mariusz
Do you have any preliminary information on dimensions (to determine what size (and height) of power supply caps might fit) or ballpark pricing? Steve
Wow Bill, that case is going to look great. Did you make the rest of the case out of metal?
